06 MC SS little/big problem
Halo went out on driver side, but not parking lights.
--This is typical of the problems with these lights. More often than not, either faulty install/wiring for the halos or a failed inverter box is to blame. Both can typically be repaired or replaced replaced for a couple dollars.
You removed the headlight and somehow blew a fuse, and now there are no parking lights on the driver side:
--Sounds like you caused something that blew the fuse, so check out all of your wiring at the headlight....then look at the underhood fuse block to the left of the alternator (inside the fuse cover is a diagram of the fuses), or inside the car on the passenger side kickpanel. You will need a manual to determine the fuses that are inside the car.
Get back to us once you find the cause, or if you need help with the repair.
BTW, did YOU install the headlights and/or wire the halos?
