A/C leak
Old Jul 14, 2010 | 12:15 PM
CTBSS's Avatar
Default A/C leak
Anyone had any freon leak issues or know if there is a common problem in the Impala SS's???
Old Jul 18, 2010 | 05:53 PM
Kazmaniac's Avatar
110,000 miles - no problems.
Reminds me I should check the pressure this weekend.
Old Jul 18, 2010 | 07:08 PM
Mels SS's Avatar
Wow 110k
Old Jul 18, 2010 | 09:34 PM
CenTexSS's Avatar
No one has really complained about A/C leaks on our cars. Is yours leaking?
The main issues we have is mde door failures.
Old Jul 18, 2010 | 10:47 PM
Kazmaniac's Avatar
Originally Posted by Mels SS
Wow 110k
Yeah - couldn't have gotten a better car! Need to get one more year out of it as a primary, but still planning on 180k before it get's rotated to "beater" status.
Hopefully by then they will have a V6 in the new Regal.
Old Jul 18, 2010 | 11:00 PM
Kazmaniac's Avatar
Wow - looks like the fitting is between the airbox and the ABS. I can't get my hand in there, gonna have to remove the airbox, but I won't do that until I get a new air filter and change it at the same time.
It's on my list of things to do this week so I will post the pressure when I take it.
Old Jul 18, 2010 | 11:38 PM
CenTexSS's Avatar
I need to check my refrigerant level also. Mine takes a little while to cool off. It's worse than my 99 Camry and 96 Crown.
Old Jul 19, 2010 | 09:07 PM
Kazmaniac's Avatar
Mine was at 25 psi @75* - added one 14oz can and was still at 25. Will add another can tomorrow.
BTW the connection is on the center firewall - real easy to get to.
Old Jul 21, 2010 | 05:02 PM
LS1 Racing's Avatar
I've definitely noticed a drop off in cooling. Especially when compared with my Grand National, which has REAL (R12) A/C.
I guess I'd better check the R134 pressure.
Old Jul 21, 2010 | 05:08 PM
Hawkins04's Avatar
what is the pressure supposed to be at?
Old Jul 22, 2010 | 09:03 PM
Kazmaniac's Avatar
Added a second 14 oz can tonight and the pressure shot up to 55 psi on my gauge @ 75* outside (evening).
My gauge is blue from 25 - 45 psi, the instructions targeted 35 - 45 psi @ 75*.
The Monte didn't like that scenario - high pressure limiter didn't turn on my compressor until my gauge showed 45 psi and then it would kick on and off. Had to bring it down to 35 psi and the thing stayed on continuously.
Drove down the highway @ 71 mph on recirc air w/ the fan on high and the car was downright uncomfortably cold - the side and back windows fogged over on the outside.
Switched to outside air and set fan to 3rd setting and car stayed cold - will need to see what it will do w/ 90* and afternoon sun now.
Old Jul 22, 2010 | 09:07 PM
Hawkins04's Avatar
wish i had a/c like that
Old Jul 22, 2010 | 10:07 PM
Kazmaniac's Avatar
Yeah that's the way it should be (est 20 oz of refrig). Should also be the same A/C systems.
