Soooo what should....
Old Jul 17, 2010 | 09:01 PM
2005gxp's Avatar
Default Soooo what should....
my next mod be? lol i have no idea what i should do next. Whats everyones thoughts here? What would be the most benificial and cost effective for me with my current set-up? See sig for mods.
Input is appreciated!!
Thanks
Old Jul 17, 2010 | 09:06 PM
indynotch50's Avatar
Do you have a good tune in it?
Old Jul 17, 2010 | 09:09 PM
2005gxp's Avatar
Hp tuners yess. being retued for the exhaust i did this week.
Old Jul 17, 2010 | 09:12 PM
Mgpeagle's Avatar
Rockers if you do not plan a cam. I went with SLP's 1.85's with oil restricted pushrods. If I would have went full aluminum rollers I would have went with 1.8 Yella Terra's or 1.8 Scorpion LS6 rockers. I'd use oil restricted pushrods with either one. That would be my next mod if I was in your shoes.
-Mike
Old Jul 17, 2010 | 09:13 PM
Mgpeagle's Avatar
After that maybe a LS4 ported intake or LS6 intake.
-Mike
2005gxp's Avatar
soo say i was to do rockers, whats Everything i would need to buy to do the install?
Old Jul 17, 2010 | 09:16 PM
Mgpeagle's Avatar
Here are a couple to look at.
http://intense-racing.com/Merchant2/...LSx_Valvetrain
http://www.byunspeed.com/product_inf...oducts_id=6817
These are all good choices and the easiest install.
-Mike
Old Jul 17, 2010 | 09:30 PM
2005gxp's Avatar
Originally Posted by Mgpeagle
say i buy these, do i absolutly need different pushrods?
Old Jul 17, 2010 | 09:59 PM
CenTexSS's Avatar
LS6 intake, nitrous, and a good tune.
Then a third trans lol
Old Jul 18, 2010 | 12:35 AM
StealthV8's Avatar
get rid of that high flow cat.. There is a huge difference up top between a highflow and no cat at all. I bought a fake cat of ebay just in case i get a random road side inspection.
Old Jul 18, 2010 | 09:51 AM
2005gxp's Avatar
this winter it will be getting a piece of pipe welded through it lol and here in canada i do legally need a cat and around ottawa they have emissions poilce that are out alllll the time
Old Jul 18, 2010 | 10:52 AM
Brian396's Avatar
You know you can gut the cat.
Old Jul 18, 2010 | 12:42 PM
2005gxp's Avatar
^ thats what i said i was gunna go in my last post, weld a pipe through it
Old Jul 18, 2010 | 03:38 PM
Mgpeagle's Avatar
You don't need different pushrods with either of those. I just did it as added insurance of any valve float. I don't get any so I am not sure if the factory ones would allow that or not. I also kept stock wide open throttle shift points too. If you have yours programmed higher than I would at least suggest the oil restricted pushrods. I also did not change the factory LS1 valve springs the car came with either.
-Mike
Old Jul 18, 2010 | 04:24 PM
fieroguru's Avatar
LS6 intake and rockers or cam.
Old Jul 18, 2010 | 04:51 PM
2005gxp's Avatar
ill be looking into the rockers for my next mod, i have shift points set at 6200rpm, so i should get some pushrods? how hard are they to do? does it involve pulling the heads?
Old Jul 18, 2010 | 05:13 PM
Haulin_Ls4_GxP's Avatar
I've got rockers, push rods, and ls6 springs I'd be willing to make you a deal on lmk
Old Jul 18, 2010 | 05:25 PM
Mgpeagle's Avatar
The pushrods just come right out. No need to pull the heads at all. Just make sure the PR's are oil restricted or you might as well just keep the stockers.
-Mike
Old Jul 18, 2010 | 05:39 PM
2005gxp's Avatar
Originally Posted by haulin_ls4_gxp
i've got rockers, push rods, and ls6 springs i'd be willing to make you a deal on lmk
pm'd!!
Old Jul 18, 2010 | 07:51 PM
StealthV8's Avatar
lol i live in canada
