W Body Suspension Issues
Fast forward to my 08 GP GXP. I bought it with 38k on the clock, and immediately replaced what appeared to be the factory tires, with a set of BFG G-Force (stock size up front and 235/50/18 rears). The traction of these tires is incredible......but the handling completely sucks compared to the worn out factory ones I replaced them with!! Even with the tires inflated to max pressure, nothing changes. I've tried all different pressure settings with minimal change. It feels like the rear is completely disconnected from the front, as it just slops around like a loose trailer back there. Feels like the sidewalls are rolling in every corner. Very mushy. Even just going down the highway at speed, and sawing the wheel back and forth. Maybe it's the slightly wider size on the narrow rim? All I know is it's freaking horrible.
So I took it back in to Discount Tire to have them checked out.....and low & behold.....the insides of every tire is worn completely bald, especially the rears. This is with about 15k on the tires now. When you look at the rear of the car, it looks like the rear wheels have a ton of negative camber at the top......but that's how every single W Body I've ever seen looks too. I just figured that's normal?
So what's everybody else's experience with the wider rear tires, as well as balding insides of the tires? Thoughts? I'm at a loss. I can't imagine the rear springs are already that worn out on such a low mileage car, or that the alignment would be that far off either. Getting that checked is my next step.
As far as the rear traction goes, i've never had any problem. My tires are just hankook ventus V4es, nothing crazy performance. I think it may just feel like that since the front does grip so hard.
Now, many W body people have had trouble with keeping camber on the rear. I don't know if there's a fix or not.
Also, is there a link to the thread about the special bolts used on the rear suspension? I've never heard about that, but sounds interesting.
I will say that when I hit a local twisty/turny fun backroad, the Active Handling Control kicks in almost constantly at the peak of every corner, and ruins all my fun. I wish there was a way to disable that... This is taking the corners at speeds LOWER than what I used to take them in my old worn out suspension Regal GS!! To be honest, I've been nothing but totally disappointed with the handling of this car.
The GXPs, to my understanding, had the staggered tires as a factory "tuned" suspension. My guess is it was their way of combating understeer. I don't know what to tell you on this. Maybe some GXP guys can chime in.
i went to auto zone and got two new rear camber bolts, they claim they make it adjustable from -1 to +1. However, my friend who did the alignment at his shop said with the bolts in, it still didn't suck the tires up enough to stop the wear. He did some clearancing on some parts and got it fixed that way. Now, some of the other gxp guys have used the bolts and said they worked just fine.
As AB eluded to, this was something done on the GXP. I did notice less grace (ever so slightly) in the rear, but it was worth it not to blow through new tires. The system would work great if you traveled on a autocross, but driving back and fourth to work it wasn't working for me.
http://www.rockauto.com/catalog/rafr...&parttype=7542
Traditional HTML (faster loading):
http://www.rockauto.com/catalog/x,ca...,parttype,7542
Is this camber bolt kit referenced above just a replacement bolt for the factory one, or is it some kind of camber-fix-it kit released after a problem was understood by GM?
Thank you all for the help btw. It is helping a great bit!
VE/Zeta factory camber adjuster:
