Cam upgrade w/DOD
Old Aug 5, 2010 | 11:36 PM
speedshifter's Avatar
Default Cam upgrade w/DOD
Hey guys,
Looking to do a cam swap and I would like to keep the DOD. I have a source where I can get a OEM GM cam for cheap, I just gotta pick one.
Stock LS4 cam is:
INT:0.283"/0.289" lobe lift
EXH: 0.283"/0.289" lobe lift
LS2 cam:
INT: 0.306"
EXH: 0.305"
'02 LS6 cam:
INT: 0.324"
EXH: 0.322"
Can the DOD lifters handle either cam? Will either cam work with the stock LS4 timing chain?
We do a lot of truck motors. I can count on one hand how many vette motors I've done.
Old Aug 6, 2010 | 06:04 AM
monte_with_a_LS4's Avatar
not to be off topic but can i see a video of ur denali
Old Aug 6, 2010 | 06:51 AM
94ss06gxp's Avatar
so you want to keep DoD and throw in a cam, what about a G8 cam
Old Aug 6, 2010 | 07:32 AM
neilownz's Avatar
Comp might have some dod cams now too if you don't wanna spend a lot on that new era g8 one.
Old Aug 6, 2010 | 07:37 AM
cuz the G8 cam lobe lifts are:
INT:0.279"/0.283"
EXH: 0.282"/0.287"
The LS4 cam has more lift than the G8. I'm using GM specs so i can't compare duration.
Old Aug 6, 2010 | 07:41 AM
I have an opportunity to get a OEM GM cam for next to nothing.
Old Aug 6, 2010 | 08:36 AM
94ss06gxp's Avatar
INT:0.279"/0.283"
EXH: 0.282"/0.287"
true.......
Old Aug 7, 2010 | 02:20 PM
nmp0098's Avatar
The is just an opinion, but I think the G8 GT cam with Crane 1.8's would be a potent DOD compatible combo with completely stock idle and drivability. The G8 GT cam is already ground with DOD in mind. I also looked at the L99 cam, but it is less aggressive and it is setup for VVT.
The first post puts the stock LS4 specs at 193/193 on 114, and the stock G8 GT at 200/208 on 116:
https://ls1tech.com/forums/ls4-front...cam-specs.html
https://ls1tech.com/forums/pontiac-g...cam-specs.html
The 1.8's would offset the small loss of lift, and the extra duration would be nice. It's a lot of work to change the cam, but you wouldn't have to pull the heads and change the lifters. The Crane 1.8s are worth 18 WHP by themselves, and you could get another 10-20 WHP from the cam.
Personally, I came to the conclusion that I was just going to with the $750 cam package over the $700 rocker package and (just guessing) $50 used cam, and take the extra HP of the big cam. Obviously the cam is a little too big without some supporting mods (not that it isn't drivable or fun!), so the other package still looks really good and won't require spinning the engine as much.
Old Aug 7, 2010 | 05:29 PM
The motor is coming out anyway to do an oil pump and lifters per a GM bulletin that pertains to a condition I'm having with my car.
I could give up DOD all together, but I like the extra MPG. I don't think its working well though because my buddy's 08 Impala SS is way faster (granted probably has the 3.29 gear and I don't) and he averages 19 ish MPG and I average 16.5 mpg with similar driving conditions.
Old Aug 9, 2010 | 01:41 AM
blakss's Avatar
Me too..Im in Illinois too can i get a testdrive. even around the block !
