New cat back. Check.
Need to still do some final tweaks, but I'll get to that later, as now I can use the drive on lift to monkey with it.
Working front to back the kit goes together pretty quickly. Yet again I was impressed with the quality and how perfectly things fit. Their is plenty of adjustment if you need to tweak angles and such. None of the pipes were ovaled on the ends during shipping, so that was a plus. Packaging is probably the best I have seen for a cat back as well, everything was bubbled wrapped like a pro, tips came through with no blemishes either. You need virtually no tools for the job, save an air gun for the two bolts at the flange after the cat and tightening the clamps down. Just make sure when you start from the front that each clamp is nice and tight before moving along to avoid any issues. A post jack does make holding some of the pieces up in place easier, but is not 100% necessary.
When you get to the tips, you need to make sure you have that half inch all the way around the bumper cover cut out. The clearance there is quite tight, looks great though. The tips are massive compared to the stockers. I have to go back and adjust them a little when the opportunity presents itself, as the shop was beginning to open and I needed to get back to the parts department.
Have yet to get a sound clip, so that is still in the works, and when I put it on the drive on lift, ill grab some pictures as well. Highway driving: cruised quite a bit in the 65-70mph range. The sound is great, windows down you can still hear the rumble but it is not oppressive or a constant drone that would put you to sleep. I still have my factory cat, and I used the resonator included with the Magnaflow kit. Wanted something that was noticeably different in the stock tone and a touch louder, but not over bearing. This kit truly fits the bill. I am happy with the fit and finish, as well as ease of installation, sound quality, everything actually. The only drawback to the system, it looks so good, that it is a shame to be hidden underneath the car. After driving it for a few days, it actually sounds quite a bit better. If any major sound changes occur, I will make sure to update the thread as well. And will work on snagging some pictures and sound clips.
