Rocking the engine
Old Aug 8, 2010 | 03:08 PM
Nick_Nasty's_GXP's Avatar
Default Rocking the engine
OK, so I am installing a shorter dogbone along with some MM's soon, and I was wondering how I would be able to rock the engine forward enough to install it. Also, how tight should I tighten the mounts to the bone? To kinda answer my own question, is it one turn past hand tight??
-Nick
Old Aug 8, 2010 | 03:18 PM
JP_GXP's Avatar
Park on a hill? Jack up the back?
Dunno how tight it's supposed to be, I always just tighten it 'til I can't anymore...
Old Aug 8, 2010 | 03:34 PM
lol Not really what I had in mind. I was thinking along the lines of pulling it forward, but with what? Is there something made to do this?
Old Aug 8, 2010 | 04:38 PM
RA4926's Avatar
Disconnect the front MM and put a rachet strap from the mount point to the radiator support and start cranking?
Old Aug 8, 2010 | 05:48 PM
Bryan921SS's Avatar
Park your car on a slight down grade...
Apply the parking brake (chock wheels if you have them)...
Put the car into Neutral...
Attach come along/ratchet strap to engine (alternator bracket maybe)...
Rotate engine forward until the shorter dog bone will fit...
I would hand tighten the bolts, and then go 1 to 1.25 turns more...
Old Aug 8, 2010 | 06:39 PM
2005gxp's Avatar
use a ratchet strap thats what i did
Old Aug 8, 2010 | 09:43 PM
BigBlackBoxChevy's Avatar
Use the biggest pry bar you can find
