Want to improve top end
Old Aug 19, 2010 | 05:33 AM
Mikzgp's Avatar
Default Want to improve top end
Like the title says. I did a guick search (top end) and really didn't see anything that stood out, but I didn't read through all of them.
All I have now is K&N intake other wise the car is 100% stock. was thinking about just adding a cut out and a tune and being done with it. I really don't want to do to much to the car.
Also any one know of a tune shop in MO????
Old Aug 19, 2010 | 05:51 AM
2005gxp's Avatar
catless dp and a tune
Old Aug 19, 2010 | 12:47 PM
Mikzgp's Avatar
well from what I have read we have a hi-flo cat so going cat less wont cahnge much but then have read it does??? so I was torn on if it would or not. I'd rather do that then a cut out
Old Aug 19, 2010 | 01:12 PM
lb06mcss's Avatar
I think I read on here that the ID of the stock downpipe gets as small as 2" so I would recommend the catless downpipe too.
Old Aug 19, 2010 | 02:05 PM
EmersonHart13's Avatar
Cat vs catless really isn't going to do much. A tune and a DP will help, maybe rockers too?
Old Aug 19, 2010 | 02:49 PM
94ss06gxp's Avatar
turbo.....
Old Aug 19, 2010 | 02:52 PM
Best advice yet.
Old Aug 19, 2010 | 03:22 PM
Nacho SS's Avatar
Did you replace just your cat with a hi flow unit or the entire downpipe?
If you take the stocker off and have a look, you'll see that the internal diameter of the pipe is like 1 3/4", spec'd right off the S/C v6 models. It's a shame a V8 has to breathe through that. Get a Hogan DP, 3" mandrel bends.
Old Aug 19, 2010 | 03:41 PM
Agreed the DP on this car is terrible. Personally I would just keep the stock cat and get the local exhaust shop with a mandrel bender to make one up. Or buy the mini pipe.
I had the Wbody Store (Hogan) catted and you get a code if you aren't tuned.
http://www.wbodystore.com/grandprix/...pes-p-219.html
Old Aug 19, 2010 | 05:58 PM
DP 08 GXP's Avatar
thats the one i got
Old Aug 19, 2010 | 06:56 PM
Valis's Avatar
Catless DP here. With the bigdaddies mechanical o2 fix. No code. Definitely improved second gear.
Old Aug 19, 2010 | 07:52 PM
AlabamaGuy's Avatar
Catless DP and a tune. These cars tend to get VERY lean after this mod and need to be retuned.
Old Aug 19, 2010 | 09:45 PM
Valis's Avatar
Speaking of tunes.. what would one do if there is no one around to tune it?
Get a custom tune on a diablosport tuner?? Just buckle down and learn to use hp tuners? Send an ECU to someone who will tune it? What's the best option?
Old Aug 19, 2010 | 10:03 PM
Hawkins04's Avatar
do not send it out for a tuner. if you cant get a dyno tune get a hp tuner or the diablosport and learn how to do it. the hp supports the trans as the diablo doesnt
Old Aug 19, 2010 | 10:07 PM
AlabamaGuy's Avatar
You're plenty within driving distance for tuners. Post in the Southern Section and get some recommendations.
Old Aug 20, 2010 | 06:26 AM
Mikzgp's Avatar
Thanks eveyone. Ya I learned to tune with every mod with my GTP. Gonna try and find a dyno tune shop.
Old Aug 20, 2010 | 01:22 PM
D J Real's Avatar
Originally Posted by DP 08 GXP
thats the one i got
x2 and are very impressed by it, but like it was said b4 if you don't get a tune it throws a code. Actully I am tune and the code came back
Old Aug 20, 2010 | 05:33 PM
Hawkins04's Avatar
you tuned the code out and it came back?
Old Aug 20, 2010 | 10:40 PM
D J Real's Avatar
Well I didn't vector motor sports did, ya it was fine for a few days then the C.E. light came on and when i took it to the dealer for diagnostics it was the PO420 code they said being caused by my down-pipe. Kinda P.O.ed about that because it causing my remote start not to work. But to their credit they said they re dyno. it for free just have to find time to go
Old Aug 21, 2010 | 12:32 AM
Hawkins04's Avatar
i wonder why it came back?
