GXP rotor help
Old Aug 23, 2010 | 03:05 AM
blakss's Avatar
Default GXP rotor help
anybody know the dimensions for a GXP rotor i need hat and diameter specs.. thanks looking to swap out rotors but think imma have to run a Camaro SS rotor and have it machined and redrilled..
Old Aug 23, 2010 | 04:19 PM
Hawkins04's Avatar
These aare the rotors i have from R1concepts
Front specs:
Description DISC SPEC Specifications for Brake Rotors
Display Value (mm or inch) mm (s)olid / (v)ented V
Outer Diameter mm 323 Outer Diameter inches 12.71
Height mm 52.3 Height inches 2.050
Nominal Thickness mm 32.00 Nominal Thickness inches 1.259
Minimum Thickness mm (Discard) 30 Minimum Thickness inches 1.18
Hub Hole/Whl Reg mm 70.7 Hub Hole/Whl Reg inches 2.78
Number of Studs 5
Bolt Circle Diameter mm 115 Bolt Circle Diameter inches 4.52
Bolt/Hole Dia mm or Stud Size 14.35 Bolt/Hole Dia in or Stud Size .562
Weight (lbs) Including Box 24.30 Mounting Type Floater
Application GM Position F
Per Car Quantity 2
Rear:
Outer Diameter mm 305 Outer Diameter inches 12.00
Height mm 50.8 Height inches 2.000
Nominal Thickness mm 26.00 Nominal Thickness inches 1.023
Minimum Thickness mm (Discard) 24 Minimum Thickness inches 0.94
Number of Studs 5
Bolt/Hole Dia mm or Stud Size 14.2 Bolt/Hole Dia in or Stud Size .559
Weight (lbs) Including Box 14.70 Mounting Type Floater / Drum in Hat
Application GM Position R
Per Car Quantity 2
