LED light conversion and flasher fix
Couldn't find anything in the manual about a flasher relay and what I have been seeing on here is that the MCSS's don't have a flasher unit, but its controled by the computer.
So a few questions:
1. Do the GP GXP's have a turn signal flasher?
2. If not, what size resitor is needed to restore normal flashing?
3. For those who have done a conversion and needed resistors, any writeups?
This is the only thing holding me back from being completely LED'd and HID'd out.
https://ls1tech.com/forums/ls4-front...ail-bulbs.html
Couple things I learned
1. You will need 4, 50watt 6ohm resistors, 1 ohm resistor for each turn signal bulb. On the Vleds website they say you only need 1 of their resistors for each side and it will fix the rapid flash. I tried it and it didn't work. Plus you want to mount the load resistors somewhere away from wires because they get very very hot.
2. Don't buy the cheap led's off ebay because the low high output difference isn't that much. I got some from vleds and they work great.
Other than that it is pretty easy. Just splice them in, there is gel in the splicers but you probably still want to put electrical tape around them to make it water proof. Don't know about a flasher relay didn't go that route and I don't know if you need something else to take care of the bulb out warnings you might get on your DIC. I didn't have to worry about that because my car doesn't have that
http://www.v-leds.com/Exterior-LED/T...46227-1-2.html
http://www.facebook.com/video/video....d=205344659982
Vleds tech support said they had some other people with similar problems only with GM vehicles but they couldn't recreate the problem on their bench and couldnt fix it. I ended up returning them. You might have the same problem.
Now does anyone know that if you install say a set of LED's in the brake / turn signal lights and keep halogens up front will the voltage difference trigger hyperflash?
To be honest, I'm a Ford man who is playing for the other side now and there is almost no knowledge that I have for fords that I can apply to GM's
To the OP I hope you can find the answer's somewhere. I have had no luck either.
So looks like I have to either wire in resistors or get used to the way the car looks without LED's.
You have to worry about the bulb out indicators though. I dont' know if you are going to do led's for all your bulbs. You would have to get one for each bulb which would be a bitch.
