- Camaro and Firebird: Transmission Cooler Information
Important information to help you understand your Camaro or Firebird
Browse all: Tranmission Guides
Transmission Cooler - MUST READ
So I installed the Hayden kit just a little bit ago, I went for a drive and and the temp stays right at 192 degrees, unless I get on it for a bit then I goes to around 197 and stays there.
Are those the results I should be expecting? I got the same kit as in 7psi write. I thought the temps should be lower.
OEM:
This is how this guy did his:
Credit goes here:
http://www.gmls4.com/index.php/topic...2.html#msg6362
would this be considered an upgrade that beefs up the transmission ?
I want to do light mods on my car. Air intake , air box ,ls6 intake...
i have an a4 00 z28 with 119k
The easiest way to beef up the trans is to add the Transgo shift kit or have it tuned to adjust shift pressures.
Good luck
