having 2 problems with my gxp:(
Old Dec 29, 2010 | 06:33 PM
TheMonteMan's Avatar
Originally Posted by JP_GXP
The last 2 sound like a fuse. Chris' issue is the shoddy LEDs, I have the same ones out and the seat works fine.
hey jp by this did you mean my issue or the ops? kinda confused. i didnt think it would be a fuse since the light kicks on then goes out a min later. figured if it was a fuse that it wouldnt light up or heat at all.
Old Dec 30, 2010 | 12:19 PM
ls4door's Avatar
makes more sense now. i was thinking of the 2 indicator lights being out...guess i been lucky 4 grand prix and never a dash light or indicator backlight quit on me. Dont hold my breath.
Old Dec 30, 2010 | 01:09 PM
JP_GXP's Avatar
The seats not working is either a fuse or the mechanism itself.
Old Dec 30, 2010 | 01:28 PM
Hawkins04's Avatar
the monteman: i think your problem is the fuse i was talking about as what you described is what happened to mine.
Old Dec 30, 2010 | 04:39 PM
i hope. i really dont want to pay the hundo for the deductible. im trying to hold out till i have a list of things bugging me.
Old Dec 31, 2010 | 12:51 PM
GXP25's Avatar
Because sharing is caring, here's mine:
Are the HUD stitches meant to be lighted? "IIII III II I O" in the following pic.
Old Dec 31, 2010 | 06:41 PM
Hawkins04's Avatar
I think the should be but not 100% certain. Do the shift lever light up like P R N D M? and has anyone chnage the lights out if so how hard was it to do as the bottom row of my climate control does not light up or the shift lever if they should?
Old Dec 31, 2010 | 07:31 PM
GXP25's Avatar
Yeah your "P R N D M" lights should light up.
Anyone else's HUD stitches light up? My page and arrow buttons light up just fine.
Old Dec 31, 2010 | 11:32 PM
Hawkins04's Avatar
ok thanks i think that will be a pain to fix
Old Jan 1, 2011 | 02:20 PM
GXP25's Avatar
Most likely.
More info with pics on the fix:
http://www.gpona.com/forums/04-08-gr...ts-t22074.html
Old Jan 2, 2011 | 04:03 PM
christopher.lazaris's Avatar
So I found out what was making the noise...my power steering was overflowing. I took it in before for the recall and they put way to much fluid and was overflowing and got all over!!! Freegen aHoles..but the noise stopped after I emptied it nd refilled it back to normal
Old Jan 3, 2011 | 08:22 AM
  #32
checked the manual and both seats run on the same fuse. i doubt its a fuse. if it was you would think the passenger seat would be doing the same thing. im going to have to brave the elements later and take a look.
