Fwi lean code
Old Jan 1, 2011 | 06:08 PM
JDMC5's Avatar
I agree, get hptuners. The stuff you listed is easy, the hardest thing on there is tuning the maf, but with some knowledge its easy.
I would probably add to that list: lean out commanded PE a/f ratio and change shift points.
Old Jan 1, 2011 | 06:20 PM
Brian396's Avatar
I havent seen that table? What is it for?
Old Jan 1, 2011 | 07:07 PM
TiredGXP's Avatar
It sets the target AFR during high load, open loop operation. (The factory raped to PE table - mine looked like the Rocky Mountains until fixed.) Factory setting gets as rich as ~10.8:1 which is way to rich for best torque.
Old Jan 1, 2011 | 07:42 PM
JDMC5's Avatar
he's right, it's basically for when you floor the car, or close to it.
Where have you seen 10.8:1? The worst I've seen is 12.1:1.
Old Jan 1, 2011 | 08:32 PM
TiredGXP's Avatar
Brain fart - 12.1 is correct, still too rich though.
10.8 is for the Subie under boost.
Edit:
Here's the current EQ table - equivalent to 12.8
Old Jan 1, 2011 | 09:08 PM
Brian396's Avatar
Alright the “lean out” thru me off.
Old Jan 1, 2011 | 09:44 PM
JDMC5's Avatar
Yeah as far as I know all the LS4's have the same PE fuel curve. At least all the ones I've seen.
Just remember brian, boosted cars like to run more rich than N/A cars. Should be around 11.0-11.5.
