6T75 6 speed conversion
of All of What is needed,
What has been Solved,
What needs to be Solved?
so we can work on what needs to be worked on,
and not work on something that has been Solved?
A) A custom oil pan is necessary to properly relocate the starter
B) A theoretical ECM/TCM solution is a possible solution to the 58x motor working
C) A custom adapter is necessary for the trans and FWD LS4 motor.
Speaking from my end. Making the custom parts is the easy part. But if the CAN bus systems reject one another, then additional programming R&D will be necessary. If someone has the engine and trans I could assist in testing "B" but someone has to take the plunge first to get at least those two.
http://www.youtube.com/watch?v=u3WlHlZfXgw
http://www.youtube.com/watch?v=gv11PVoiL_c
View from the transmission toward the engine:
View from the engine toward the transmission:
Link
The 6T70/5 have a little pocket on top of the transmission.
Here's a video of an LS2 + 6T75 matted together and turning over:
B is possible as you mentioned over the phone. However, like you said, there are issues with the E40 24x cars.
The same guy who put the above stuff together is a PCS (Powertrain Conrol Solutions) engineer working on getting this transmission to talk with ALL of our vehicles (and others). Apparently it's done. It's all a matter of testing and torque management.
C is not a problem and is done as well (yellow and cyan parts in the CAD drawings above).
But yes, it's the electronics which are the hard parts.
Custom Flywheel (with cad prints):
10" clutch/pressure plate:
Bolt on Starter Bracket to keep the LS4 starter:
All done but finishing up the wiring harness:
Converting to RWD doesn't do much for this.
With money not being much an issue:
For traction purposes, AWD. For RWD "effectiveness" and feel, new car.
The swap is on hold. We are waiting on PCS or someone with an E67 wanting to try out what TrueBlueGTO suggested.
So anyone in New Jersey, step right up.
