87 Octane Tune: Mission Accomplished!
yes, timing's role in gas mileage is maximizing power at part throttle. Thats actually how you tune part throttle timing on a dyno. Your basically getting the most cylinder pressure out of the a/f mixture, I.E. the most torque, to keep the vehicle moving at the lowest possible throttle position. Otherwise you would have to introduce more a/f to get more power and in turn use more gas.
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
So, it definitely is possible to drop down to 87 Octane, even in a high compression motor like the LS4, and not lose fuel economy.
Now it's just a matter of how much HP loss we'll see. And I'm wondering if the usual mods will help off-set the loss of HP. In other words, with the mods in my sig and an 87 octane tune, could I perhaps expect near-stock performance, instead of being down HP?
LS1Tech Sponsor
you'll have better performance than stock, even with the 87 octane gas...
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
__________________
06MonteSS / DiabLew Tune
![](https://ls1tech.com/forums/signaturepics/sigpic53380_2.gif)
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
We'll fillup with 87 in the next week or so, and I'll get a log.
Lew, is there anything additional that you'll need to be logged for this project?
LS1Tech Sponsor
hahaha.. don't need logs for any tcm/tranny stuff... but there ARE a lot of parameters to log for the engine side of the tune man... fuel trims, timing, knock retard, rpms, intake air temp, etc etc etc... just to name a few... hahaha...
LS1_Racing - just log the usual that I need....
air fuel ratio (Equivalence Ratio)
commanded throttle position
engine speed (RPM)
intake air temp
long term fuel trim bank 1
MAF Sensor Mass Airflow
spark advance
total knock spark retard
engine speed (RPM)
intake air temp
spark advance
__________________
Looks like I'll be doing the log today. My wife mistakenly put 87 in it when she filled up yesterday. Apparently, she got used to driving our Saturn for the last month while the Impala was getting the trans work done. So, we'll top it off again with 87 and run a log.
Lew, do you need me to flash back to a stock tune with no DoD for the log?
LS1Tech Sponsor
LS1 - nah, no need to flash back to stock... the 91 octane tune you have in the car now uses the stock timing table already... so that's why I want a new data log with that tune in the car, to see what the timing is doing, KR levels, where KR occurs, how much, etc etc...
JDMC - correct, well, kind of.. he's using the 91 octane tune, not the diablo/93 octane tune.. and the 91 octane tune, uses the stock timing table... but I still want a data log to see any KR levels.. I could just reduce the timing by -2* or whatever, but that doesn't mean it's going to be enough depending on how his car's running... and I don't want to just do a blanket change of the timing table.. I'm going to pinpoint the problem areas by rpm, g/cyl, etc... so yes, I do want a data log - and that will give me all the info I need...
__________________
#33
#34
Did my log last night and sent it to Lew.
Surprisingly, when running 87 octane fuel with Lew's 91 octane tune, I still get less KR than I used to get with 91 octane fuel and the stock tune.
#35
If the timing tables are the same then it's a matter of fueling, I'm sure with his tune your getting more precise metering of the fuel warding off KR.
#36
not that it matters but where do you see the KR when you see it? I would expect you are seeing it during throttle changes and WOT.
I attached the log, if anyone is interested. I had to upload as a .tun file so I could ger around the limitations of the site. When you download it, you'll need to change the file extension to .log. To view the log, you'll need DataViewer, which is a free download from the DiabloSport website.
#37
engine speed (RPM)
intake air temp
spark advance
engine speed (RPM)
intake air temp
spark advance
Edit: Unless Diablo uses different PID names than the Tech II and HP Tuners, that is...
#38
LS1Tech Sponsor
on the newer vehicles, "knock retard" would show the max allowable retard setting for a particular area...
"total knock spark retard" shows you the actual retard value of how much timing is actually getting pulled at that point of KR...
so... I want to see what is actually happening and the actual amount of timing being pulled at the point of KR... don't care what the max is that it would allow...
and yeah, don't really need to see burst knock.. that won't tell ya anything about actual/real knock happening...
yep, I know all about that man... have done this a few times before ![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
and I'm not advancing it anyway... I'm looking for any areas where it may need to be reduced, if he's getting excessive KR (more than 2*) anywhere when using the 87 octane gas...
__________________
#39
Maybe this is a naming thing, but there are two Knock Retard PIDs, one called Knock Retard (in a Tech II and HP Tuners) and one called Total Knock Retard (in a Tech II and HP Tuners). The one called Knock Retard behaves as you describe above, while the one called Total Knock Retard includes Burst Knock as well. You can find Burst Knock Retard by subtracting Knock Retard from Total Knock Retard.
#40
Update on our progress:
We're on the second iteration of the 87 octane tune, and we're fighting our way through some heavy KR issues at crusing speeds under moderate load (up hills and stuff). There was a huge improvement from the first tune to the second, but there's still some pretty ugly stuff under load.
Lew will probably be taking another stab at this on Sunday, and I'll update again when there's more info.
