Transmission question
Old Jan 25, 2011 | 10:56 AM
reality1's Avatar
Default Transmission question
Has anyone tried a 160 degree thermostat with water wetter to reduce transmission oil temps?
Jim
Old Jan 25, 2011 | 11:11 AM
EmersonHart13's Avatar
160 would be too low for the engine. No one really recommends changing the thermo, especially to a 160. They do recommend setting the fans to come on earlier though.
The way to go is a dedicated trans cooler. Read some posts via the search and you will see.
Old Jan 25, 2011 | 11:52 AM
LS1 Racing's Avatar
Agreed.
I would add a cooler, but omit the factory cooler in the radiator. All it does is add heat to the system. The difference on my car was about 15 degrees cooler just by removing the factory one from the circuit.
Also, our cars already have a 180 or 185 t-stat. And the LS motors don't really run better below that.
Old Jan 25, 2011 | 12:57 PM
06MonteSS's Avatar
LS1Tech Sponsor
correct... what they both said... ^ ^ ^ ^
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
