Rims
Old Mar 2, 2011 | 06:26 PM
GXP05's Avatar
Default Rims
Anyone know if these rims and tires will fit an 05 gxp?
http://cnj.craigslist.org/pts/2186861116.html
Old Mar 2, 2011 | 06:54 PM
2005gxp's Avatar
sure they will, but the tires are pretty small(height)
Old Mar 2, 2011 | 06:58 PM
GXP05's Avatar
yeah, i was just gonna use those tires this year at the track and then when they're done i would get radials or slicks
Old Mar 2, 2011 | 07:05 PM
RedHotG8's Avatar
With a 24mm offset they will stick out past the fenders.
Old Mar 2, 2011 | 07:11 PM
2005gxp's Avatar
yeah, my 35offset 9inch wide stick out a bit 24offset definately would.
Attached Thumbnails Rims-img00100-20110220-1321.jpg   Rims-img00083-20110214-1724.jpg
Old Mar 2, 2011 | 07:17 PM
GXP05's Avatar
They would stick out more than your offset?
Old Mar 2, 2011 | 07:27 PM
RedHotG8's Avatar
Right, the lower number puts the offset of the wheel further out.
Old Mar 2, 2011 | 08:57 PM
The Guz's Avatar
If you are not lowered the wheels should fit with no problems. If anything the rear fenders may need to be rolled. Also just as a reminder, those wheels use the 5x114.3mm bolt pattern. W-bodies use the 5x115mm bolt pattern. Those wheels will still fit.
