GM is making a part to stop oil consumption
Old Nov 4, 2011 | 11:54 AM
  #41
blueguy's Avatar
I don't suppose anyone has heard if the part is ready or not?
Old Nov 4, 2011 | 03:10 PM
  #42
WhiteGXP313's Avatar
The dealer called me about a month ago but I didn't return his call. I already disabled the DOD which stoped the car from burning oil so I see no reason to take I in.
Old Nov 4, 2011 | 04:14 PM
  #43
AlamoTA's Avatar
From what I've read about this issue with the '07 Suburban's 5.7, it's an oil baffle installed in the oil pan. It only works about 50% of the time. Tuning seems to be the trick. However, if your car is under warranty, I'd stick with the GM fix. Maybe they've gotten a better fix now.
Old Nov 4, 2011 | 07:06 PM
  #44
Andrew91PGT's Avatar
I talked to pontiac customer service 2 weeks ago and as on then it was still not available. The dealership recommended constant oil changes, fuel injector top end cleaner and oil additives to keep the rings from seizing.
Old Nov 4, 2011 | 07:42 PM
  #45
GXP25's Avatar
GM really should be complimenting owners by topping off their oil every time the low engine oil light comes on.
Old Nov 7, 2011 | 11:58 AM
  #46
blueguy's Avatar
Yeah, at the rate it's going, I'll probably have to put in another 2 or 3 quarts before the oil change is due. Isn't burning this much oil bad for the cat and/or O2?
I'll take mine in next week and at least get things started and see what they say.
Oh, also getting what sounds like piston slap once in a while. Is this related or is it something else? If I can talk them into replacing the pistons and rings, I'll be happy.
Old Oct 12, 2012 | 08:26 PM
  #47
Weaslespit's Avatar
Anybody have any updates on this? Was the bulletin updated or another issued? I also have the smoke occasionally when the DOD kicks off, usually after coasting and then tapping the accelerator.
Car is an '08 with 83K so I am out of warranty... Any word on how much this costs?
Old Oct 15, 2012 | 03:39 PM
  #48
El Cid's Avatar
The bulletin has not been updated.
I've had the repair completed (top end decarbonization and oil pan gasket replaced) and my oil consumption is acceptable now. It actually does not consume oil now at all, but I credit some of that to Overkill programming my PCM to have DOD active only in 4th gear.
Mine will still puff smoke like yours, so this does not repair that concern.
Labor time to complete repairs would likely be 9.1hrs, plus parts.
See my original thread for part numbers. https://ls1tech.com/forums/ls4-perfo...l-fix-ls4.html
Old Oct 15, 2012 | 03:49 PM
  #49
LS1 Racing's Avatar
I'm fairly certain the Montes and Impalas only go into DoD in 4th gear on stock programming, while the GXPs will see it in 3rd and 4th.
Old Oct 16, 2012 | 09:25 AM
  #50
El Cid's Avatar
My 2006 MCSS would enter DoD in 3rd gear prior to the reprogram.
Copied from General Motors SI for a 2006 MCSS:
Displacement on Demand (DoD) System Description
System Operation
General Motors Displacement on Demand® (DoD) engine control system has the ability, under certain light load driving conditions, to provide maximum fuel economy by deactivating 4 of the engines 8 cylinders. The engine will normally operate on 8 cylinders in V8 mode during, starting, idling, and medium or heavy throttle conditions. When commanded ON, the powertrain control module (PCM) will direct the DoD system and deactivate cylinders 1 and 7 on the left bank and cylinders 4 and 6 on the right bank, forcing V4 mode.
It doesn't specify what transmission gears it is active in.
Old Oct 16, 2012 | 10:26 AM
  #51
LS1 Racing's Avatar
System Operation
I know what DoD does and how it works, but I had always heard that the calibration in the two Chevys allowed DoD activation only 4th. I know that my Impala will not go into 4-cylinder mode in 3rd.
Perhaps Lew can chime in and shed some light on this!
Old Oct 16, 2012 | 12:20 PM
  #52
The_Madcat's Avatar
I can verify the 3rd and 4th gear DoD on the GXP's. Drove me insane so I had Dave tune out 3rd when I had the trans done. I have it completely off in the tune now and will have it removed hardware wise very soon.
Old Oct 17, 2012 | 09:56 AM
  #53
El Cid's Avatar
My intention to provide the information was to share with all who read this post, and the forums. Sorry if I implied otherwise.
Old Oct 24, 2012 | 06:27 PM
  #54
Weaslespit's Avatar
Thanks for the update El Cid!
Old Nov 14, 2012 | 04:14 PM
  #55
Tom_Monaco's Avatar
I have had the oil pan gasket replaced and it is starting to smoke again. That doesn't help.
Old Nov 28, 2012 | 02:11 PM
  #56
Tom_Monaco's Avatar
The Buick dealer is repairing my engine again. Last I heard they are replacing the pistons, rings and not sure what else. Will update with what they do and if it helps.
Old Dec 1, 2012 | 08:08 PM
  #57
cderry's Avatar
GM put on the new updated oil pan gasket in July which didn't help the issue so GM approved installing new pistons and rings. All is good so far with two months in and 2000 miles on the car. Car had been burning oil for the longest time. I figured since I was still under warranty why not get it done before I sell it next year.
