Tuned by Vector
Old Jun 9, 2011 | 07:11 PM
ryanisl33t's Avatar
Originally Posted by 06MonteSS
oh, and I misspoke in my previous post.. 2005's are also supported... so it's 2005's and 2006's are the only ones supported...
winnar winnar chicken dinner!
Old Jun 9, 2011 | 07:47 PM
D J Real's Avatar
Originally Posted by 07whiteGXP
Lew-Good call.
The plan of action I thought of this morning is:
1. Drive the car with Vector so they see what is going on
2. Re-apply stock tune, drive around again to see if everything is back to "normal"
3. Strap up on the dyno make the first run with stock tune for baseline
4. Apply the canned tune, make another run to see any power difference
5. Make adjustments and run again
6. Repeat step 5 until statisfied
7. Drive around and make sure everything is good, then go home happy
Does that seem reasonable?
ya except this is their busy season, hopefully they will have the time do do multiple dyno runs. Good Luck man I'm happy Vector is trying to work with you, they have always done good by me.
Old Jun 9, 2011 | 07:52 PM
JDMC5's Avatar
it's easy to tell if its the tune or not... did you keep your stock modules?? swap 'em out!
see if it's like that with the previous tune...
and if ya didn't keep your own set of stock/previous modules, well, then I dunno... me, I would never have my original set overwritten... just in case some weird **** went on with the tuned set, then at least you could put the previous set back on and be up and running...
I agree, should never trash the stock tune. Also, like previously said, put it back to stock and see if it goes away. With his level of mods, one shouldn't be messing with tables that would cause potential driveability issues either.
Old Jun 9, 2011 | 08:57 PM
07whiteGXP's Avatar
Well I'm hitting the dyno Tuesday afternoon - I will update with my results. Thank you for all the input everyone.
