Best Tire Combo Dilemma
The front KDW's were the stock size, but the rears were a bit wider/taller, because I couldn't get the rear stock size in the KDW. Those tires were decent for traction up front, but not great. However, it always felt the rear end of the car was just totally disconnected....kind of like a trailer following the front tires after a few seconds. Just horrible handling. The rear tires lasted about 9 months, before the insides had belts showing, and the outsides still looked almost brand new. Guess I should have installed the rear camber kit. Maybe that's why it handled so badly?
Since I had to replace the rears before the fronts were ready, I bought a cheapo pair of stock sized Goodyears for the rear. In January this year, the fronts were bald, so I had to replace them too. I installed stock sized Goodyear F1's up front only, since the rears were new. The F1's have horrific traction! 1/4 throttle off the line, and they're already spinning. It's plain goofy! And still, the car handles like complete and utter crap. Nobody else can even stand to drive the thing... Active Stability control comes on daily, when I push it around any corner.
I type all of that out to paint the picture of where I am at now, and what I'm going through. I want to replace all four tires with a complete set of the absolute best handling and best traction tires I can get for it. Would wider 275/40/18's up front that I've read about, better help with the horrible traction while taking off? If so, great....but what will they do in the handling department? If I run the 275/40's up front, what would the best tire size be to compliment the rear?
I push this car hard daily, that's why I bought it. I like to drive hard. I need a tire that will give the absolute best handling first and foremost, and best traction when taking off, second. I sincerely appreciate any feedback! Thank you. Btw, I posted this on GMLS4, but thought I would post here as well for more input.
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
EDIT: And 245/45s are great in the back. I'm gonna try stock rear size with 275s when I need new rears.
Do the 275/40's handle better or worse due to the extra width on a narrow rim? Do they actually offer more traction over the stock front tire size?
If the 275/40's are run up front, are the 245/45's the preferred rear size to match the front?
Thanks again guys for the help. I really do appreciate it!
245/45s are what everyone runs, but like I said when the time comes I'll try 225/50 paired with the 275s.
Also suggested are Hankook V12's. What other brands of tires have a great balance of handling & traction in these tire sizes?
Doing the math, the stock are 27"s tall up front, and 26.9"s tall in the rear. The new proposed tire setup would reduce the height a small fraction to 26.7" front & rear. Would this make much of a noticeable difference with the speedometer or more importantly, the odometer?
Still out on which brand of tires would be best for traction & handling, in a 275/40 front and 245/45 rear. So far I've heard the following:
1.) Hankook Ventus V12
2.) Michelin Pilot Sport A.S Plus
3.) Pirelli P Zero Nero
I'm tempted to run another set of BFG KDW's, but in the new wider sizes...
So I got my car aligned this morning. The camber wasn't that far off from spec, but the toe was horrendous on the rear. While we were under there, we discovered that all my hub bearings are tight, but the rack & pinion has a LOT of play in it! Not good, and I hope it's covered under the GM 100k Powertrain warranty. That would explain why it has always felt like the steering has a mind of it's own. Even scary to drive at times if the pavement is rutted.
The passenger side lower motor mount has a lot of movement in it, and the upper dog bone mount is fawked. The tranny whines nicely when it gets warmed up, and the bottom end still sounds like it's gonna fall out when I crank it....at least twice a week. Ugh. New tires may be on hold for awhile, until I can get all the warranty crap handled. I can't stand dealing with the dealership.
http://www.coopertire.com/html/produ...age=zeon_rs3_s
http://www.coopertire.com/html/produ...age=zeon_rs3_a
