DOD timing chain replacement
Question, has anyone had this issue? It's annoying like a baseball card in a bike tire annoying, it's very audible with the windows down and I wouldn't be surprised if any pedestrian's in the downtown area where I live think there is a 10-speed with an LS4 strapped to it coming up behind them. Dealership won't do anything about it...
Has anyone changed this timing chain or know the level of difficulty/cost in replacing it? I really don't want to drive around in 2nd gear just to eliminate the noise.
What are the other possibilities? I mean ALL 16 lifters and the entire transmission have been replaced, the noise was there before and after.
when I searched for a 5.3 DOD I got the 12639516 as being the correct lifter, I couldn't find what the 12576400 was for, but something tells me if they cost half as much for half as many (so 1/4th the cost) they are not correct.
Again, I'm no expert on the DOD but something doesn't seem right.
If it were DOD solenoids activating wouldn't it be a transient noise? Based on some of the DOD system stuff I've read the entire cylinder deactivation cycle takes less than 250ms. The way I understand it is that the solenoids shouldn't change states unless they are commanded to by the ECM. Since the noise is constant I'm guessing it's not the solenoids.
I also don't need to be in drive for it to activate, 3rd gear in tapshift mode creates the same scenario as long as I don't get on the throttle. If I do it goes away.
