just ordered some drag radials :D
I know center caps can be changed, I have Pontiac centers on Mustang wheels.
That's a sale/example photo, so it had me a bit off.
EDIT: Shelby does make aftermarket wheels.
http://www.carrollshelbywheels.com/truck-wheels.html
Case closed.
Back on topic, ETA of radials?
Case closed.
Those are dam impressive! How much heavier are they over stock? Can you weigh a stock wheel/tire and the drag set up for me?
Also, what tire pressue did you use? My car is happy with 16-18psi depending on track prep and weather. I would recommend some spring blockers for the rear too.
I have hit 1.9's with my set up with goobs of tq down low. I was hooking dam good the last time I went out.
1.7's is my goal so I am hoping for 12.3's. with traction only.
Can't wait for gears and conveter!!
Get som blue masking tape and tape off your fenders and doors.
Nothing like doing a 80mph burnout with rocks stuck the tires and flinging out. I have a bunch of new chips now
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
#32
Nothing like doing a 80mph burnout with rocks stuck the tires and flinging out. I have a bunch of new chips now![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
