ls7 exhaust manifold install : -)
Old Jul 17, 2011 | 07:34 PM
SigmaX6's Avatar
Default ls7 exhaust manifold install : -)
I will update pics as I get them. So far the ac hoses got in the way and had to go.
I drive this mostly on hwy so its no biggie. Might figure a way to get the ac hooked back up later.
Just went to upload pics and uploads are disabled. Got 7 pics lol
Will try again when I get to a pc. My android is my main means of getting online.
07 gxp, intake, ported ls4 intake manifold, trifecta tune, gears, sonix sure cure kit, shift kit, trans cooler, 3 inch dp, 3 inch exhaust
Old Jul 17, 2011 | 07:37 PM
DavidGXP's Avatar
So the car is on the road now?
Old Jul 17, 2011 | 07:38 PM
Low91's Avatar
I've been contemplating putting some on my MCSS. Are you going to run the front pipe under the oil pan or over the trans? Do you think there will be any clearance issues below the rear manifold?
TheJPGXP's Avatar
Wish I could ditch my A/C... In for pics.
Old Jul 17, 2011 | 07:55 PM
DavidGXP's Avatar
I have thought about ditching the A/C a million times. I have only used it about 5 times. It never really gets hot enough up here in Washington except in August.
Pull the compressor and build a bracket with a pulley attachment. Then ditch the rest of the crap thats accessable. I just don't want to ruin my car.
Old Jul 17, 2011 | 08:40 PM
TheJPGXP's Avatar
Maybe when it becomes a dedicated track car...
Old Jul 17, 2011 | 09:07 PM
gxp-miller-gxp's Avatar
no jp, we might actually die without ac here lol
Old Jul 17, 2011 | 09:17 PM
ImpSS07's Avatar
^^x7 on that
Old Jul 17, 2011 | 10:03 PM
SigmaX6's Avatar
It'll be ready on wensday.
We havnt done a ac delete basically just removed and tapped off the ac lines. Still no luck uploading pics yet. Is it cause I'm mobile or my account?
Old Jul 18, 2011 | 01:52 PM
Gripenfelter's Avatar
I'll upload the pics for you to photobucket Shane.
We will be going up and over the tranny with the exhaust piping. The LS7 manifolds hit the A/C hard lines right at the compressor so the only way to keep A/C would be to have custom A/C lines made that bent towards the nose of the car at a 90 degree angle as soon as they left the compressor.
In other words, A/C line delete is necessary in most cases.
Old Jul 18, 2011 | 02:15 PM
These pics show how the LS7 manifold on the front interferes with the A/C lines. It sits right on top of them. We have since removed the lines.
Old Jul 18, 2011 | 02:28 PM
1Fast7's Avatar
The radiator hose looks a little close there.
Old Jul 20, 2011 | 12:47 AM
Crossover pipe done. 3".
Will do the merge pipe tomorrow.
Old Jul 20, 2011 | 01:08 AM
SigmaX6's Avatar
I knew the extra ls7 parts I had would help alil : -)
Old Jul 20, 2011 | 12:48 PM
Sittingmongoose's Avatar
I thought the ls7 was cathedral ported and wouldn't work on other ls engines except the ls3
Old Jul 20, 2011 | 01:47 PM
DavidGXP's Avatar
Thats on the intake side. Exhaust is the same.
Old Jul 20, 2011 | 01:48 PM
DavidGXP's Avatar
So did you guy's swap out the rear manifold too?
Old Jul 20, 2011 | 01:53 PM
SigmaX6's Avatar
Yea I believe he did.
Old Jul 20, 2011 | 02:07 PM
Yup and the funny thing is the exhaust ports on the heads are oval. Could benefit from a good porting.
Kind of pointless to just do the front lol.
I'll have more pics tonight.
Old Jul 20, 2011 | 04:30 PM
Im an idiot i thought the thread read intake manifold lol
