Trading in Monte, Complete LS performance kit being sold
I never got to install any of this on the car, never found the time.
Well, I got the car itch and decided it is time for a new car to play with so I will be trading in my 07 SS. I will be selling a COMPLETE LS6 manifold/Rocker Arm/Coil/ kit. I will be posting here in classifieds to give forum members first shot before I put it on ebay. I really want to sell the whole deal at once and NOT part out the pieces. As soon as I can get some pictures taken, I will post . Included will be:
1) Modified LS6 intake manifold (new take off): Rear vacuum ports removed and plugged, right side neck vacuum port removed and plugged, new map sensor attached to rear, bottom ground flat, painted,
2) New Felpro intake manifold gaskets (with bottom foam)
3) Custom aluminum adaptor to attach LS4 thottle body, machined for vacuum port/PVC port.
4) LS4 throttle body (used but excellent)
5) Modified aluminum DOD Valley cover with gaskets and solenoids, (used but excellent) Oil pressure sensor tower cut and welded at 30 degrees to allow room for LS6 wider intake neck.
6) Modified DOD wire cable to fit under LS6 intake.
7) Modified LS4 fuel rails to fit LS6 manifold
8) Set of LS4 fuel injectors (used/excellent :cleaned)
9) Scorpion 1.8 aluminum Rocker arms (new)
10) LS6 yellow valve springs (new)
11) Proform LS valve spring compressor tool (new)
12) LS4 painted valve covers with NEW bolts
13) Set of higher rated LS truck ignition coils with brackets Used/excellent (both sides)
14) New set of Bosch ignition wires
15) New set of Autolite iridium plugs
16) Spare MAF sensor (used but excellent)
EVERTHING YOU NEED BUT THE TOOLS
I will entertain offers while I am deciding on a price
Pics of things might help too since you have some "modified" things for sale.
It's been raining so much around here, that I haven't had a chance to get everthing photographed yet. I will soon. I am not firm on prices, I just want this stuff gone. Heck for the $1200, I would also throw in my Superchips 2950 Cortex tuner .
