Spraying the gxp
Old Sep 12, 2011 | 05:31 PM
06GrandPrixGXP's Avatar
Default Spraying the gxp
im running a 100 shot with the tr6 plugs (there free) i was gonna run tr7 but no sense in waistin money all i have is the diabew tune any suggestions?... its an nx kit heres a few pics
http://s950.photobucket.com/albums/a...t=IMG_8439.jpg
http://s950.photobucket.com/albums/a...3DIMG_3253.jpg
Old Sep 12, 2011 | 05:36 PM
also does anyone know if there is a plate kit for our cars?
Old Sep 12, 2011 | 05:59 PM
TheJPGXP's Avatar
Where's Rossko when we need him?
Old Sep 12, 2011 | 06:05 PM
ive heard about him lol do you know of any vids with our cars sprayed.. i cant find any
Old Sep 12, 2011 | 06:08 PM
TheJPGXP's Avatar
I don't think there are any.
Old Sep 12, 2011 | 06:13 PM
ill make a few then lol... do you reccoment puttin anti sieze on the plugs when i change to the tr6s?
Old Sep 12, 2011 | 06:14 PM
TheJPGXP's Avatar
No clue, not a nitrous guy... yet.
Old Sep 12, 2011 | 07:23 PM
ryanisl33t's Avatar
Not a bad idea to put antiseize on the plugs anytime you change them. As far as the kit goes, looks like a pretty basic wet nitrous kit, I wouldn't worry about getting a plate. Just jet that nozzle you have, and go. You could have Lew pull a little timing for you on your tune. Could also invest in a window switch to avoid spraying though shifts, as our trannys are already junk.
Old Sep 13, 2011 | 12:29 PM
06MonteSS's Avatar
LS1Tech Sponsor
don't put anti-sieze on plugs!
newer plugs have a coating on them, which is usually silver, sometimes with a greenish or golden tinge to it, it`s not bare metal (dark or black in color)
Why not use anti-seize compound?
1 - you can easily over torque it and deform it without even knowing or even worse pull the aluminum threads right out of the head. Dry and Wet torques are totally different installed values.
2 - if any manages to get to the insulator or tip shorting/misfire will occur.
3 - it acts as an insulator and prevents proper heat exchange between plug and head/water jacket.
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old Sep 13, 2011 | 02:24 PM
06MonteSS's Avatar
LS1Tech Sponsor
and don't use used plugs lol.. get new ones, correct ones for our cars..
you can find 'em at ls4store.com
__________________
Old Sep 13, 2011 | 04:01 PM
i was told those plugs are just colder idk im lookin into it lol ima find out more
Old Sep 13, 2011 | 08:18 PM
06MonteSS's Avatar
LS1Tech Sponsor
yes.. you want them to be one heat range cooler man... that's why you want the tr6ix plugs instead of the stock tr5ix... the tr6ix is one heat range cooler
and you want to gap them at .035 instead of .040
__________________
