Couple of LS1/LS6 intake swap ?'s
You can use the stock injectors. The fuel rail will need excesive modification. The mounting tabs are in different locations and the fuel rail crossover will need to be bent for more clearance. You will also have to do a little intake manifold grinding for fuel rail clearance.
The TB will not bolt-on without an adapter.
