Lights, Pillars, and Bow Tie. Done!
Old Oct 2, 2011 | 04:23 PM
SRTH8R's Avatar
Default Lights, Pillars, and Bow Tie. Done!
Head lights and pillars were faded out so spruced them all up. Just have Tint and exhaust left.
Old Oct 2, 2011 | 05:07 PM
xxtheshockerxx's Avatar
looking good
Old Oct 2, 2011 | 06:38 PM
SS07's Avatar
Ah nice, that is excatly what I want to do to my headlights. Since I think all the aftermarket headlight options for the Impala stink I wanted to tint eyebrows and the amber reflector just like that. What did you use? I was planning on using the VHT Niteshades and just masking off the area with blue painters tape. I also thought about buying the pre-cut tint film for the headlights and cutting out the area I want tinted. Whatever you did it looks good. I dont want it quite that dark as I want to be able to see a little of the amber reflector.
Old Oct 2, 2011 | 07:13 PM
SRTH8R's Avatar
Looks darker in the pic. I just used vht. They were faded and turning yellow across the top. I just sanded all the factory clear coat off. Then I used pinstripe to lay out my pattern. Then laid my tape out and cut along the pinstripe. Sprayed the vht, peeled the tape off, 3 coats of clear. Wet sanded with 1000 grit, polished with a buffer. Just a temporary fix for me until I can get a new set. Time consuming but a easy weekend project. Post pics when you do yours.
Old Oct 2, 2011 | 07:14 PM
SRTH8R's Avatar
Oh and I find I get a better line using the green tape. FYI.
Old Oct 2, 2011 | 09:15 PM
SS07's Avatar
ok sounds good, thanks for the tips. the stock headlights are actually not that bad looking. what would be great if a company could build stock headlights but have a clear (white) reflector in the corner.
Old Oct 2, 2011 | 09:28 PM
SRTH8R's Avatar
You could always make your own. Split them and make a clear reflector.
Old Oct 2, 2011 | 10:07 PM
1CL3ANSUP3RSPORT's Avatar
Looks good,I sure do miss my smoked tails
Old Oct 3, 2011 | 03:34 AM
SS07's Avatar
I have heard that opening the headlights up can be a real PITA.
Old Oct 3, 2011 | 03:38 AM
green manalishi's Avatar
looks good....but i dont think anyone on here is ever truly done lol
Old Oct 3, 2011 | 09:08 AM
SRTH8R's Avatar
Just done with those parts. It's the wife's car so not a whole lot will be done.
