Transmission?
Old Oct 3, 2011 | 09:20 PM
hurley_21_07's Avatar
Default Transmission?
Well I hoped it wouldn't happen to me....
4th gear started to do that thing where it feels like a misfire for about two days and now it started whining and making a cshhhhhhhh sound. Also fluid went to a brownish color. Should I try adding fluid if it is about a quarter inch over 'Add' after driving it?
I'm screwed aren't I...
Old Oct 3, 2011 | 09:21 PM
P.S. It whines in all gears and does the misfire feeling thing in other gears too now it seems.
Old Oct 3, 2011 | 09:43 PM
CenTexSS's Avatar
Doesn't sound promising. Don't add more fluid id it isn't low. Is it misfiring or shuddering when the TC is locked?
Old Oct 3, 2011 | 10:04 PM
The engine is running perfectly. I just wanted to kind of convey the feeling of what it does. Feels just like a misfire but its not. It's the tranny.
Old Oct 3, 2011 | 10:18 PM
SS07's Avatar
sounds like a pump of some sorts...
Old Oct 3, 2011 | 11:31 PM
LS1 Racing's Avatar
The whine is usually either the converter or the front pump.
It doesn't sound promising, though.
Old Oct 4, 2011 | 12:53 AM
TheBlizzard's Avatar
Interesting, I was sitting at a gas station today just idling and my car made this hiteous whining/screeching noise from the engine bay. The car was in park and was warmed up. And I am experiencing the same issues you are as well, mine is going to the dealership tomorrow to see what is up with it.
But it sounds like the transmission is the problem.
Old Oct 4, 2011 | 03:08 AM
SS07's Avatar
Yeah from my past dealings, my dealership wont address any whining or misfire like symptoms. Guess I am just going to have to wait until the tranny goes completely for them to fix it, hopefully it will be sometime soon, so I can say I told you so...
Old Oct 4, 2011 | 07:52 PM
Well it officially will not stay in gear. Only when I got it to 60-65mph would it stay in gear. Could it be only the pump or is that still uber expensive?
Old Oct 4, 2011 | 08:18 PM
SRTH8R's Avatar
If the pump goes everything gets smoked.
Old Oct 4, 2011 | 08:58 PM
LS1 Racing's Avatar
Just to clarify, I said the pump is likely to be causing the whine you hear. It may or may not be the cause of your problems with staying in gear.
Anyway, your trans needs a rebuild.
Old Oct 5, 2011 | 08:20 AM
I figured as much, but something in me was still clinging to hope, LOL.
It's now parked. I don't want to look at it for a few days.
Thanks guys.
Dan
Old Oct 7, 2011 | 09:49 PM
What could cause the trans pump to only work directly after starting the engine?
Old Oct 8, 2011 | 01:57 AM
DavidGXP's Avatar
A stock rebuild up here costs 1900 plus 600 for removal and installation. So about 2800 after fluid and tax.
If I didn't do engine mods and trans mods, I could have bought LS1racing's Buick and had an 11sec car! (I think this might become my new sig.)
Old Oct 8, 2011 | 09:40 AM
LS1 Racing's Avatar
Like I said, you're not going to know what it is until you get it apart. It may not have anything to do with the pump.
Old Oct 8, 2011 | 09:41 AM
LS1 Racing's Avatar
And now the Buick is sold.
Old Oct 8, 2011 | 10:39 AM
Gilbert@Ace Racing's Avatar
The most common reason that happens is that the filter is picking up excessive amounts of clutch material and misc debris from the bottom of he pan and is become so clogged that fluid cannot pass through it.
And if that is the case changing the fluid and filter will do no good as the internal damage is done unfortunately. It would be a waste of time and money to just service it at this point.
Hope that takes a little mystery out of it for ya.
g
Old Oct 8, 2011 | 05:26 PM
K I will post what I find out when I get it apart. Thanks again guys.
