engine or trans problem
Old Nov 18, 2011 | 08:06 AM
blackimpalass's Avatar
Default engine or trans problem
Hey guys. Well the other morning I was on my way to work and on the highway my car was bucking pretty bad felt like its shuddering. So I took it to cotman figuring the trans is bad. They had it for the night and he calls me and said its an engine misfire but the car is showing no codes but on his computer it says it is misfiring. So they changed the plugs and wires but he says its still misfiring. Any ideas?
Old Nov 18, 2011 | 05:43 PM
So I picked my car up today its still missing but it does run alot better. The old plugs looked horrible. The car has a random misfire code and a temp sensor code. But the check engine light is not comming on. Would the temp sensor cause a misfire?
Old Nov 18, 2011 | 07:04 PM
rm08gxp's Avatar
Ive had a similar issue w/ a stratus 2.7 it ended up being a lower intake manifold gasket. hth . I was also not getting any cel's
how many miles? ever changed the fuel filter? there are so many things that can cause a misfire.....
Old Nov 18, 2011 | 07:32 PM
08GXPLS4's Avatar
if there is a temp sensor code i would check and see what the temp is reading. if the temp is open or shorted to power that will throw the fuel trims way off. get some more info and let us know
Old Nov 19, 2011 | 05:27 AM
Deimos's Avatar
tell gim to pull up misfire data and watch it from there. That was you can pin point where the misfire is.
Old Nov 19, 2011 | 06:10 PM
Took the car to work today ran good on the way down but comming home it was running rough again. Its only part throttle seems to run great wot. So not sure what's going on
Old Nov 20, 2011 | 12:51 PM
ghetto joe's Avatar
is the exhaust hot? maybe a bad cat converter?
