Transmission Fluid Change
Old Jan 11, 2012 | 12:54 PM
06ssImpalame's Avatar
Default Transmission Fluid Change
So I'm thinking about changing the transmission fluid this weekend in my 2006 Impala SS, only because I just hit 60,000 miles and it has never been done. I am just curious if anyone knows how many bottles of transmission fluid I am going to need and also the best brand.
Thanks so much for any input on this
Old Jan 11, 2012 | 01:02 PM
JessmoMonteSS's Avatar
You will need 8 quarts of Dex VI (takes about 7.5 quarts so keep an eye on the level when you get close). You should pick up a new filter as well. Look for metal chunks/shavings in the pan because it should give you an indication of how your tranny is holding up. Good luck!
Old Jan 11, 2012 | 01:17 PM
Excellent thank you so much for your input, I plan on definitely getting a new filter also! Did my car come with Dex VI? and if not will it be OK using that?
Thanks
Old Jan 11, 2012 | 01:46 PM
Yup Dex VI is what's in it right now and is what GM recommends using for our tranny.
Old Jan 11, 2012 | 04:21 PM
Thanks so much for your prompt replies!! Very Helpful
Old Jan 11, 2012 | 04:23 PM
EmersonHart13's Avatar
Dex VI is the only way to go. Take photos of your pan, fluid color, and magnet and post them here for the experts to review.
Old Jan 11, 2012 | 05:09 PM
xxtheshockerxx's Avatar
i did mine at 39k. only after 2000miles of me driving it. just to know it was done. mine wasnt really bad. the fluid was discolored and had small shavings but nothing major.
here is mine
Old Jan 11, 2012 | 05:57 PM
06chevyimpss's Avatar
Mine looks black as in close to being motor oil and it had sluge like substance on the pan!
I will try n post pictures up soon as i get them …
Old Jan 11, 2012 | 08:53 PM
straitchev's Avatar
Changed mine a few weeks back. Use brake cleaner to clean out the pan. When tightening the bolts to the pan, they dont need much torque. Run the transmission through each gear and check the fluids.
