Water pump location
Old Jan 12, 2012 | 04:17 PM
MillerMonteSS's Avatar
Default Water pump location
I just wanted to be sure. I am experiencing a coolant leak in this general area.
Is the red line pointing to the water pump? Thanks for the patience...
Old Jan 12, 2012 | 04:20 PM
RsSean's Avatar
Yes that is the water pump, there is a weap hole in the bottom of it. More than likely that is where the leak is coming from.
Old Jan 12, 2012 | 04:26 PM
Sweet. So, should I just replace it? I have the car torn apart right now. I figured I would replace the serpentine belt and the water pump. I can't actually see where the leak is coming from, it just looked to be coming from behind that pulley.
Old Jan 12, 2012 | 06:08 PM
smokin06impala ss's Avatar
Yes replace it and please dont buy duracrap like me. I had to replace it 3 times so I went with one from NAPA autoparts and no more issues.
Old Jan 12, 2012 | 06:11 PM
It's looking like the AC Delco version is for me then. Anything else I should do while it's torn apart?
Old Jan 12, 2012 | 06:13 PM
Excellent choice !! Besides replacing the belt I think thats it.
Old Jan 12, 2012 | 08:34 PM
rm08gxp's Avatar
check the idler pulley's for any play/ bearing wear
Old Jan 14, 2012 | 06:15 PM
Thank you Impala06SS, Smokin06ImpalaSS and rm08GXP...
Got the pump out and could see where the impeller blades contacted the aluminum. That hose clamp on the tensioner WORKS GREAT! I think that it was just the gasket that was causing it to leak, but I'm going to go ahead and get the AC Delco pump that was recommended.
Old Jan 14, 2012 | 06:54 PM
hazards280's Avatar
+1 I had to do this on my GXP once as well. It sucks but when it's all over the peace of mind is worth it!
