Cam and intake question
http://www.diablewtune.com/package_deal.html
and no, the tune would not be on it already... custom tunes have to be made from the copies of tune files from your specific car, because the tunes are tied to a vehicle's specific VIN and engine calibration ID's....
so, you'd order the deal, then when you'd get the Trinity in about a couple days, you'd need to install one of the diablo preset tunes into your car, so that the trinity would save the original backup stock tune files in it...
then you'd save a copy of those "original backup" and "last tune written" tune files out of the trinity to your PC - email them to me - I create the custom tune for your car based on those files and email the custom tune file back to you.. you import it into the trinity, then connect the trinity to your car and install the custom tune.
correct, there is a separate TCM module for the tranny, and yes, the Trinity can adjust the tcm/tranny tune settings as well... have had my tcm/tranny tuned since last December
All the info you'd need can be found on my site http://www.diablewtune.com and yes, I'd need to know your vehicle's info - year/model, what mods are done to it, etc.
Thanks for asking man, I appreciate it!
-Lew
Then I installed a Magnaflolw catback , 1.8 rockers, CAI, and a LS1 intake that was tuned by Lewis, and a put down 276hp/299tq with number 4cyl. injector unplugged.
All stock, I trapped 98-99mph, with a 238whp. After installing the cam and such, as posted before, I trapped 111.33 mph. This would put me around 355-360 whp. I do not plan on getting dyno'd again. I perfer trap speeds
This cars race weight is 3865 with me in it and 1/8th tank of gas. Best ET was 12.71.
I now have ported heads, lighter valvetrain, std volume oil pump, and a built trans with 3.69's.
With the new heads, the car feels like the cam swap all over again.
yeah, can definitely get that car crankin' without having to go the whole big $$ cam/intake swap route...
Here's what I was able to do with DavidGXP's setup last year:
http://www.gmls4.com/index.php/topic,64.0.html
Lew was very quick with making changes to my tune, after receiving my logs.
I think it took about 8 logs lol.. I was using the Predator at the time.
Camshaft
*Camshaft retainer plate*
LS7 lifters
LS2 lifter buckets
Head gaskets
Head bolts
Pushrods
Valve springs
Katech valley tray http://store.katechengines.com/modif...take-p149.aspx
Katech opsu adapter http://store.katechengines.com/oil-p...px?Thread=True
LS6 intake (Send the intake to me for a fee, and I will do the proper mods for you)
Brian's TB adapter
Stock Injectors with http://fuelinjectorconnection.com/sh...&productId=212 adapters. Make sure you get the Lower injector O-rings!
LS6 fuel rail (returnless)
Map extension harness
If you shop around you can find so screaming deals..
I would hit up Chance707, to find out what he would let everything go for, since he has been there and done that.
I wish someone who lived close to me, would get serious.. I could do the whole dam swap, and could use a little extra $$
and I would be much cheaper then a shop, and could get most parts for a fraction of their costs!* Do not take a chance on reusing the retainer plate unless your engine has less then 50K. Their is a embeded oil seal that is in the plate to seal off the oil galleries. The plate is less the 30.00. *
Camshaft
LS7 lifters
LS2 lifter buckets
Head gaskets
Head bolts
Pushrods
Valve springs
Brian's TB adapter
I spoke to my buddy and he said he ran a 13.9 and his trap speed was 99 if I can remember. I know that I pulled a couple of cars on him without the magnaflow his had the magnaflow. Whats the quickest stock GXP/LS4 run? I believe I read somewhere (a while ago) it was a GXP and it ran a 13.6 @ 102 if im not mistaken. Ive been out of the game for a while excuse my ignorance.
