manifold swap help
Jason
That's where I'm stuck at :/
7-16" drill is the proper size for a 1/4-18 pipe tap
As for the DOD connector.. The connecter sticks up to far in the tray, and causes the intake to rest on it. You have to remove the upper portion of the connector and extend the wires. Use soilder and heat shrink with a little epoxy in order to seal everything up. The DOD tray is the hardest part of the swap.
