map extension
Old Sep 22, 2012 | 01:41 PM
baltsk8er69's Avatar
Default map extension
Middle of an ls1 intake swap. Map extension to map sensor side will not clip. The maf pins seem larger than map extensions slots. The harness to extension side has to be forced in. Any help?
Old Sep 22, 2012 | 01:46 PM
nmp0098's Avatar
I cut the wires and soldered inline extensions into the harness, effectively reusing the MAP sensor.
Old Sep 22, 2012 | 01:48 PM
Am I supposed to use the ls1 map sensor? Or is that harness suppose to adapt to our map sensor
Old Sep 22, 2012 | 02:24 PM
nmp0098's Avatar
I'd reuse your stock LS4 sensor. The sensors have a linear output, but there might be a different slope and offset for the LS1 sensor. You can fix that in HPTuners by looking at a factory LS1 tune from a car with the same part number on their MAP sensor.
Old Sep 22, 2012 | 02:31 PM
I'm just curious why other people had no problem using the same extension from ballenger on the same map sensor....a little confused???
Old Sep 22, 2012 | 02:44 PM
lVloses's Avatar
I ran into the same issue! With research I found out that 05-06 GXPs uses the LS1 MAP while 07-08 used a different MAP. This information should be added to the sticky so some of us don't waste $20 on an extension we can't use >
I did read you can unclip the MAP wire from the wire cluster and it should stretch, or you can just extend it...
Old Sep 22, 2012 | 02:48 PM
Yeah I have an 08 imp ss. Thanks for the help. I tried opening the clip up I gained like .5 inches....heating up the sodering gun now.
Old Sep 23, 2012 | 11:47 PM
DavidGXP's Avatar
Yes, the 05-06 LS4's use the LS1/LS6 MAP sensor, and require the harness in my sticky. 07-08 use's an improved sensor, and will need a different harness. I will add the harness to my sticky if someone is able to proved me with a P/N.
The sticky is geared towards the 05-06 LS4 and needs to be updated.
Old Sep 24, 2012 | 09:16 PM
Yeah I have an 08...map sensor was different...but it reached its taught but not tight. My coolant cross over lines had to be massaged away from the underneath bottom of the new mani. Ac lines had to be bent out of the way to clear the evap solenoid hose. Power steering resoivoir return line had to be slid up and the clamp turned. The dod harness took quite a bit of work. I shaved the dod connector down to just the barbs...then didn't modify the pcm side of the clip. Plugged it in mani pushed down on it but it worked.
By Brett Foote | 2026-06-04 05:00:17
