Horrible Gas Mileage
I am not writing this because I expected 25 mpg all day.
2006 GXP...102,000 miles and it great running condition.
THis tank was the first since purchasing the car where I actually have driven easy and tried to see what it would do mileage wise. I have not had it on the highway much, but the surface streets out here are pretty much like a highway and it has not been in any traffic. I have not beat on it and only driven it lightly since I filled it up 2 weeks ago.
The display is reading that I am getting 13.7 MPG, 190 miles since fill up, and estimated fuel left is 54. This sounds horrible for the way i have been driving. Any thoughts as to what may be wrong? Or is this normal?
I just would think that driving it easy around town would get me at least 17-18mpg.
Oh and nothing has been done to the car. Completely stock.
-That's your answer right there.
Last year I moved into a city which doesn't allow me to commute to work using mostly 55 mph highways, like I used to. Now I have to go from light to light and never get above 45 mph (unless I'm feeling frisky). I also drive much more in the city too, just doing random errands. I have seen a significant drop im MPG. I used to average 16-18 mpg. Now I'm at 14-15 mpg. I don't care how much you baby it in the city, it's still going to suck the gas down quickly. Make sure you get a true MPG reading and not just from the display.
Right now im getting about 18mpg but i dog it all the time when i drive it. If i drive 60mph on a freeway i'll get my 25+ mpg again.
Back when we lived in IL, I made two 11 mile trips a day, but about 6-7 miles of each trip was highway, and one of them was in the middle of the night. I was getting 18-20mpg then.
*shrug* Its a 300hp+ V8 in a 3600lb+ car. Both my C5 and my Z28 were better, but they were also quite a bit lighter.
With winter gas I could see it dropping a bit too, I know mine has
Have you checked your cold tire pressre?
Cold weather and winter gas will cause a lose of fuel mileage. 2-3mph's!
Fuel your tank up and reset your trip odometer. Calculate your fuel consumption when topping the tank back off, once empty.
My average fuel economy is 18.7 and and this car; even when new.. never seen better then 20 average.I just went through 16.4 gallons of gas and got a little over 16 mpg. On my last road trip I got 22 mpg.
So i filled up again and checked my tire pressure. The fronts were at about 25psi which is low and the rears were ok. This could be causing the issue but from what i am reading, expecting the 18 city is just a dream.
My average mpg for the last tank, being gentle with the throttle was 13.7mpg.
Depending on your foot you should see 2-5mpg increase mixed.
Another note. When you accelerate you need to see less than 2000 rpm or more than 3000rpm.
Holding right around the 2700-3000 mark is pretty rough on the transmissions. Because that is where the tq converter locks up. Sounds strange but it is really rough on the tq converter. You either gotta lock it up good or not at all.
