Anyone have this happen before??
If not go here and download it:
http://www.gm.ca/media/owners/manual...nual_en_CA.pdf
If you do go to page 5-122 and check the fuse marked CANISTER (passenger side kick panel)
Also go to page 5-126 and check the Emissions 1 and Emissions 2 fuses
Also do you have any mods , cold air intake, exhaust
Also can you tell me what scan tool you are using to clear the codes.
First the car must be cold (at least 8 hrs. off) open the car door with the key, not the key fob. Get in and sit, touch nothing... with the key fob double click the lock and immediately the auto start. Remember don`t touch anything! Now let it run on its own for around 5 minutes, listen for a tap, tap, tap sound like someone is tapping on the window behind you.(sounds like someone snuck up and tapped with a key on the window lightly, very distinctive) There will only be 3 taps and it will only happen once in a cold start cycle. If the car shuts off (auto start runs out of time) and you did not hear the 3 taps then replace the solenoid. If you do hear the 3 taps then return the solenoid to the dealer.
PS. the low battery caused the fuse to blow as the draw to the heated o2 sensors is a lot.
Thanks for all the help..
I was a bit worried . Seeing as I spent about 1250 dollars on trinity lew tune intake and dp with cat riggt as all this stuff started happening
I did notice that when I install cai that.my pcm and tcm wire harnesses were all chewed up.. by the dead mouse that was in my fuse box..
How did he do this when he was dead?? Haha jk
Anyway going to attempt the tape tjese all up but its bad.. if anyone has a link for new wiring for our cars I'd love to see how much it would cost..
Call your insurance company this should be covered under your policy, if not you can get a new or used harness to replace the ABC one (already been chewed)
Didn't check around evap but both o2s wires seem ok..
Just updating my issue in case someone happens o have this problem in the future
