trans leak
Old Apr 27, 2013 | 08:35 PM
tonypaul's Avatar
Default trans leak
I just finished swapping a LS4/4t653dh into my Lambo Diablo kit car. The transmission has a leak right where the cooler line goes into the trans. Is there a O-ring or something in there?
It just had a little drip at first, then I tightened the fitting about a 1/4 turn and now its leaking really bad. I used the factory lines to an external cooler/fan but never took off the trans hoses off when I did the swap so I have no idea how the fitting is sealed. I would like to know what I need to fix it before I take off the hose.
Thanks~
Old Apr 27, 2013 | 09:04 PM
baltsk8er69's Avatar
Yes. Move the plastic cover off the end of the line. You will reveal the e clip. Use an oring tool to pull the clip. Pull the line out. I believe its a 19 mm wrench to unscrew the fitting. They're around 30 bucks from the dealer.
Old Apr 27, 2013 | 09:32 PM
tonypaul's Avatar
Thanks! Ok just to be clear- do I need a whole replacement line or just a o-ring?
Here is a pic of where its leaking-
Old Apr 28, 2013 | 10:26 AM
I run a shop so I used an oring from a fuel line repair kit. The oring is inside fitting. But they don't sell juat the oring. Maybe go to your local parts store and buy an oring assortment. Much cheaper than buying the new fitting
Old Apr 28, 2013 | 11:36 AM
tonypaul's Avatar
Thanks! I got a O ring kit somewhere around here, I will pull it apart and see if I got the right size....
