Bigger Radiator
Old Sep 30, 2013 | 08:30 PM
08 pimpala ss's Avatar
Default Bigger Radiator
Does anyone make a bigger radiator for our cars?
Old Oct 2, 2013 | 10:09 PM
baltsk8er69's Avatar
I've never had a cooling issue, have you?
Old Oct 2, 2013 | 11:04 PM
91parkave's Avatar
Moderator
Yea that radiator is pretty good if anything just have your tuner scale your fan power higher at 192-198 degrees
Old Oct 3, 2013 | 09:25 PM
Well i was having a few issues with it running warm found out that the low speed wasnt working all the time the ground for the fans behind the pass headlight was corroded and fuse box connection were kinda nasty also problem fixed cleaned up the ground and beefed it up a bit with some 8ga she is good now.. and the real reason i was asking about rad is ive always had a big *** 4 core on my other cars
