Planning on getting a gxp and need some info.
Skydog
When I replied that the rear ends blow in f-bodys the reply was oh no biggy bro, just throw a 9inch in. Okay? So just throw a better trans in our cars right? Nope that's erroneous I guess. Every platform has it's pros and cons.
Cracks me up.
Carry on though.
Cracks me up.
Carry on though.
Then I wonder the purpose of this thread? Sorry, tranny is junk, comparing it to the 10 bolt is kind of a desperate argument. There is a big price difference of a tranny against a rear differential. There are much better and reliable cars in the same category as these cars.
Carry on....and unsubscribed. Delusional people cracks me up too.
I actually didn't plan to buy the car I did end up buying. I don't like the Sport Red Metallic paint very much and it didn't have a sunroof, but the car felt stronger than the others I test drove. Sure the transmissions are a weak link and the car is very heavy, but it is a good car. Don't let the negative slow you down too much. Mine has been completely trouble-free thus far.
Now, if you (the OP) assume that you're going to have this problem, buy the car and put aside money for a built trans, then you're on the right track. But, if you buy one assuming that "with proper maintenance, it will be fine" and ignoring the failure possibility, then you're basically sticking your head in the sand and are likely in a for a rude awakening.
If money is a concern, you can be back up and running after a 10-bolt failure much quicker and cheaper than a 4T65 failure.
Anyway, this is a ****-poor comparison, because a 10-bolt won't fail unless you abuse it in a 6-speed car. Our transmissions fail due to factory design flaws, and many (including mine) have failed regardless of fluid change interval and presence of a cooler.
And for the record, I've owned 3 4th-gen LS1 cars, all with moderate to heavy mods, so I can speak to both cars.
Now you're talking!
A perfectly good used 10-bolt can be had for a few hundred dollars and can be installed in a couple of hours in a driveway. A used LS4-spec 4T65-HD is anywhere between $500-$1000, with R&R running $600-$1000, and you wouldn't know for sure if it was good unless you took it apart first, or just gambled that you weren't being scammed and installed it anyway. Because of this, and the rarity of the LS4-spec 4T65, most wind up going rebuilt or remanufactured, which ends up being in the $2500-$3000+ range.
This! ^
This too! ^ Just don't get a factory remanufactured trans, as you'll have the same problems, eventually.
Now you're talking!
Hmm...This thread mentions a lot about power window motors, warped brake rotors, water pumps, and the aforementioned 10-bolt. Yes, folks mention various electrical issues and pinion seal leaks, but are you really going to compare these things to a $2500+ LS4 trans job??
Well said. These cars have earned the reputation they deserve, its not the owners fault, its GM. Time has shown that in general they are crappy unreliable cars with a nice engine and...that's about it. Im sorry to say that F-bodies are much more reliable. Its not an opinion, its a FACT.
F-bodies were brought up because ALL platforms have issues. It just depends what you are willing to deal with when the time comes.
A reminder...posted by you.
But hey! Its your money, you want one of these cars?.....good luck, from the bottom of my heart, you're gonna need it.
I simply stated that the 10 bolt sucks. Should people shy away of the platform because of that? I don't want one of these cars, I own one already. But thanks for being concerned about my moolah!
