Trans speedo unit options?
Old Nov 3, 2013 | 10:30 PM
LS4 swap's Avatar
Default Trans speedo unit options?
Are there any different tooth count speed sensor options for our 4T65EHD, for doing gears and wheel changes to keep the speedo close?
Old Nov 3, 2013 | 11:30 PM
91parkave's Avatar
Moderator
HP tuners will solve that
Old Nov 4, 2013 | 10:24 PM
LS4 swap's Avatar
OK, but is there a speed sensor that will work and give a choice of tooth count.
Old Nov 5, 2013 | 12:03 AM
91parkave's Avatar
Moderator
If you were to change the tooth count it would still need to be programmed in the pcm.
Old Nov 5, 2013 | 05:56 AM
fieroguru's Avatar
ZZP sells a couple, 34 tooth and 38 tooth (I think stock is 30). However, even they recommend changing it in the ecm.
http://shop.zzperformance.com/store/...tor-Wheel.aspx
