hp tuners?????
Depends what your wanting to do & how much you want to do yourself. I can say it's easy to datalog with and can use with wideband O2. Plus, there is a lot of people on the forums that help.
Dude i not a pro at that stuff but that means u are way rich and i would undo what u did first the maf is somewhat trickie on our cars but 91 parkave should be able to help more than me
Moderator
^^^this. go back to base factory file VE table. under diag MAF freq set to zero. on high and low, set codes P101,P102,P103 to mil on first error. then set your dynamic airflow high and low tables to 8192 and 8191.
make sure when you scan. your table display dosent have any MAF related items.
this is the meat of everything. details of course are in various writeups all over hp tuners forums. but ill help you out.
