Glowshift oil sandwhich plate installed
Got this sandwhich plate installed to get rid of the drill tap job i did on the oil cooler block off plate. This unit is verynice and comes with everything needed for your install minus what you need for putting a oil pressure sensor in. this block comes with 4 x 1/8 NPT oil ports.you can install any type of oil related gauge sender/cooler lines you want with this.
Price was 30 bucks found here
Note for 05-06 LS4's you will want the 13/16th size. for 07-08 just google your oil filter thread size.
http://www.glowshiftdirect.com/oil-f...16-thread.aspx
![](http://i173.photobucket.com/albums/w63/91parkave/IMG_20140110_114613_zpsubpqzts3.jpg)
i had to use a 1/8x1/8 male to male adapter plus a 1/8 to 3/8 NPT adapter..available at your local hardware store..as always use thread sealer or teflon tape on ALL connections.
![](http://i173.photobucket.com/albums/w63/91parkave/IMG_20140110_182446_zps3zyim11o.jpg)
Everything installed with oil pressure sending unit installed in.
![](http://i173.photobucket.com/albums/w63/91parkave/IMG_20140111_095547_zpsvoe6i4dv.jpg)
Remove your oil filter and clean the mating surface with a rag
![](http://i173.photobucket.com/albums/w63/91parkave/IMG_20140111_100716_zps5axmr6n6.jpg)
Tighten the nut and install filter, NOTE the adapter piece that holds ont the housing is a 27mm. heres a pic with everything installed, Also note that i would not use a extended oil filter with this installed.
![](http://i173.photobucket.com/albums/w63/91parkave/IMG_20140111_112627_zpsple22lzi.jpg)
![](http://i173.photobucket.com/albums/w63/91parkave/IMG_20140111_112548_zpsqmgudneq.jpg)
this is with a standard oil filter, right on level with the subframe.
![](http://i173.photobucket.com/albums/w63/91parkave/IMG_20140111_112609_zpswsjpc2ve.jpg)
So something I noticed today after my top swap, oil pressure at the oil filter is about 7-9 psi higher than on the VLOM. I always thought it was a faulty glow shift gauge but nope. Stock engine sensor reads the same down there. Cause I used to monitor my oil pressure on aeroforce when it was stock and my glow shift gauge was always 7-9.higher and I thought it was a bad gauge
