May need struts
So the prix is going into the shop on wednesday for an oil change and while its there they're gonna check out my back end. Making a clunking noise on every pot hole and even on little tiny bumps and even the odd red light, when I come up to it, will make like a vibrating little clunk.
Usually I guess that's struts but they said it can sometimes be sway bars but they'll find out next week.
So that all brings me to my actual question lol. I have read numerous threads on the stock struts being discontinnued for our cars, yet I have seen summit racing have a pair of Bilstein ones for our cars when you enter in the search criteria.
Can somebody tell me if I can still get replacement ones or will I have to ship em out to Bilstein?
Usually I guess that's struts It is possible for a strut to fail prematurely but these are bilsteins and should easily go the distance, 100000 miles but they said it can sometimes be sway bars More likely the sway bar end links, a very common problem. Request the MOOG problem solver units as they are far superior and greaseable. but they'll find out next week.
So that all brings me to my actual question lol. I have read numerous threads on the stock struts being discontinued It is a FACT they have been discontinued, there are some in warehouses in the country but you must find them and usually the will be over priced due to this fact. for our cars, yet I have seen summit racing have a pair of Bilstein ones for our cars when you enter in the search criteria.
If you have any leaks now then yes it is possible for them to get worse. Just remember that an oil leak is also a vacuum leak and that alone will cause you more grief than the oil leak. So if you have any leaks now fix them and do the switch.
I'd be personally going with the comfort.
They took my car for a spin and they found the noise mainly happened when turning, especially when the weight was on that back wheel.
They hoisted it up and looked at the strut and it seemed ok... though they are going to be digging deeper into this when they have more time (I was tight for time so told them just to do a quick examination). They also determined the sway bars and end links, bushings, etc. were all ok.
So as of right now we have no idea what it could be. In the spring they're going to actually get in there and take the struts out to see.
So if it is in fact the struts, is there a replacement I can get that is very close to what the stock ones are? I won't be changing the front ones so will having a different model of Bilstein on the back hinder the way the car handles?
I don't go to tracks or anything... but I still want to keep everything as close to stock as possible.
Also, of course they tell me sometime i'll need new brakes at the back... anything you guys recommend that doesn't cost too much?? Again, don't wanna stray too far away from stock if I can't pick up stock ones.
For the brakes I would recommend getting the OE replacements.
How much does the problem solver units run you?
Strut mounts are probably your issue if they found nothing else wrong. You can find the parts on rockauto or amazon.
Your original end links may pass the test for the ball stud looseness test, but as I mentioned some of the sway bars came with larger or elongated holes and the snapping noise comes from the stud moving in the larger holes. The problem solver units take this in account and also upgrade the ball sockets/joints and makes them grease able too. As for the price here it is double of what you can get them in the USofA.
Here is another KNOWN problem:
GM recommends you trim off the tabs on the isolator and to apply a thick grease in the areas indicated.
I'd hold off though as I should be getting my end links tomorrow or Friday. I purchased both the Moog and Mevotech end links just to see which one is thicker.
http://www.1aauto.com/2005-08-pontia...=659701&y=2008
And if it's not too hard to do, I went ahead and got that Moog problem solver endlink. Is it fairly easy to swap those out yourself too? Any links to the procedure? I haven't found any through google yet.
Any other ideas?
I'm in the same boat as you. They're clunking bad out back. They're also over $200 each so I'm holding off a bit. I also plan on raising the car so that's another $200 for new springs.
So over $1,000 for me. I wish I could spend that money on performance upgrades (headers, finish my intake swap).
