Question?
Old Mar 9, 2014 | 07:36 PM
Bigwayner07's Avatar
Default Question?
I've got this muffler sitting in my garage. Its a cherry bomb extreme. Single in dual out its small. Like a flow master super 10. Will it fit my GXP?
Old Mar 9, 2014 | 11:55 PM
neilownz's Avatar
No you need a single in and out with one side offset and the other centered for each side. 2-1/2" I think. Just look under the car and do some measuring.
Old Mar 9, 2014 | 11:57 PM
SSelDiabloBlanco's Avatar
Its 2.25" not 2.5
Old Mar 10, 2014 | 12:06 AM
91parkave's Avatar
Moderator
You can make pretty much anything work however making it practical is another story.
You should get under the car and see if it can work.
Old Mar 10, 2014 | 02:24 PM
Thanks guys!
Old Mar 10, 2014 | 04:08 PM
blkchevyz's Avatar
i did that on mine with a flowmaster. it was a single in dual out, replaced the y pipe with it then made some tail pipes.
would probably be easy work for a muffler shop if you cant weld it yourself.
