New front Poly motor mount
I spent a good couple of hours today working on mine and got no where.
I got the car on stands, took off the dog bone, loosened the nuts on all mounts, removed the nuts on the front and lifted the engine slightly.
I removed the black plastic housing that covers the fog lights, lower fenderwell, etc. and had no success gaining access to the bolts on the lower or upper portions of the mount.
I feel like a moron and like I'm missing something very simple.
X11 has answered all of my questions and the poly mount looks like the utmost of quality by the way!
https://ls1tech.com/forums/ls4-performance/1592428-motor-mounts-oh-motor-mounts.html
The responsiveness is great.
Mine does vibrate more than the stock one - it's especially harsh when the motor is cold, going in reverse and when I go from low load to loading the motor at 2k or so RPM.
I have DOD disabled so I'm not sure why - however it's worth the responsiveness. Perhaps another mount is bad/going bad?
Thanks for the great mount - glad to finally have it installed.
Note that it's not missing - car only shows misses on cylinder 8 if it misses at all.
Plugs are tr6ix with msd wires (all new).
I'm thinking my dog bone is pretty well shot so I'm changing that out to see if it improves at all.
Glad you got it installed! I'd be curious to find out why your getting that kind of vibration. The movement you mentioned - is that at idle?
Cheers
Before the mount install if you popped the hood a lot of the hoses, Cai box, etc vibrated. If you looked at the mufflers they moved too.
You can feel it if you touch the motor. Now with the tighter mount nothing really moves. Car runs and drives great, good on gas, etc.
Vibes aren't unbearable by any means (I used to drive a 3100 malibu with all poly mounts, phone would vibrate across the dash @ idle). I was just a bit surprised as for the most part people reported no change in vibration.
Either way, not the end of the world. Was just a little surprised (especially by idle) as folks said no increase in harshness. Just posting more wondering if anyone has any ideas.
I like the crispness and responsiveness, this unit is very well designed!
I still find strange you have the vibration - my motor is super smooth at idle, both before and after the mount install. Glad your happy with the mount, let us know if you find anything that might be making it run a little rough.
Cheers
Thoughts?
This explains my low load vibes; I'm going to see my tuner and make sure its disabled for good this time.
I installed an intense dog bone and my idle vibrations have been reduced, my launch vibration reduced, my dod vibration insane and of general harshness at low speeds and high RPM increased minimally (very tolerable).
Again - mounts are awesome.
Edit - got the intense mount in fine
