New front Poly motor mount
Old May 4, 2014 | 08:03 PM
x11 nut's Avatar
Default New front Poly motor mount
Yes, it's homemade - but stout !!
I'm still waiting for prototypes of drop in replacement poly mounts, but needed to do something because my front mount was shot....
Some searching turned up Energy Suspension 4.1104G Transmission Mount with "close" to the right bolt spacing. Just need the stock mount base and a piece of 3/16 x 2" steel.
Pics should say the rest...
Old May 4, 2014 | 08:12 PM
x11 nut's Avatar
The mount bracket needs to have the holes elongated...
Old May 4, 2014 | 08:15 PM
x11 nut's Avatar
Time for paint...
Old May 4, 2014 | 08:20 PM
x11 nut's Avatar
Compare stock vs new poly setup...
The stock mount compresses 1/4 - 3/8" when installed - so although they line up even unloaded, the poly will not compress the same. I did not use the second steel sleeve as it made installed height to high because the poly does not compress.
Old May 4, 2014 | 08:29 PM
x11 nut's Avatar
Now the install - the mount was out for opening the bolt holes. The easiest process is to bolt the poly mount to the bracket and install, then place the bottom piece in cradle slots, then bolt lower bracket to mount, then lower engine and tighter lower mount to cradle.
Special note - due to thickness of stock mount bracket, the bolts that comes with the poly mount are not long enough - you'll need two 7/16-14 x 1" bolts.
Old May 4, 2014 | 10:12 PM
91parkave's Avatar
Moderator
Niiiiiice.
This is awesome to see another angle on a common problem. I had to re work mine shorter than stock as well plus its good to have a little preload with the motor tilted foward . I had to redrill my dogbone and decided the dogbone should be used I didn't want the cradle and/or block mounts to crack or be under to much stress. Mine survived the first track passes. Well see in the future lol.
Old May 5, 2014 | 06:57 PM
08 pimpala ss's Avatar
Looks good man
Old May 6, 2014 | 08:11 PM
supercatxr7's Avatar
good job!
Old May 6, 2014 | 08:43 PM
x11 nut's Avatar
Thanks guys!
After a couple days of driving I can say I'm very happy with it - very tight now, no loading up - just goes !!
Old May 6, 2014 | 08:53 PM
Originally Posted by x11 nut
Thanks guys!
Now u need to make another one for me
Old Jun 25, 2014 | 10:13 AM
x11 nut's Avatar
Hey Pimpala,
You break it yet ??
Old Jun 25, 2014 | 09:59 PM
Hey Pimpala,
You break it yet ??
Well with u knowing my track record of my breaking stuff AKA Mr destructor
I have not broke it so it must mean that just maybe u did something right this time Lol And i dont see my self breaking it anytime soon!!
This Mount that X Nut Made Is The **** He is the man!!!!
Old Jun 26, 2014 | 07:26 AM
x11 nut's Avatar
Lol, thanks man - happy to hear its doing well!
Old Jul 7, 2014 | 08:30 PM
IMPALAZL108's Avatar
how can i order one lol
Old Jul 7, 2014 | 08:36 PM
x11 nut's Avatar
Drop me an email or PM...
Old Jul 13, 2014 | 09:38 PM
Matt Barrett's Avatar
whats the price of one of these?
Old Jul 14, 2014 | 12:17 AM
Send x11nut a pm Its worth every penny Got one on my car and i tend break everything and its holding strong now for awhile now
Old Jul 14, 2014 | 05:33 PM
PM Sent!!
Old Jul 15, 2014 | 08:37 AM
x11 nut's Avatar
PMs replied, I'll do several by end of the month.
Cheers
Old Aug 15, 2014 | 10:31 PM
Thanks X11 Nut for the mount. Great finished product and a professional, clean design. Just comparing the two mounts side by side in person, one can see how "squishy" the stock mount is compared to this. I installed my mount a few days ago and today did some hard pulls and normal driving around town. Mount feels solid, no additional vibration, and although my car already shifts quick/hard due to the Cartuning trans build/tuning, this mount is definitely one of the missing links I needed for my set up to help get the power to the ground and make the mounting points more solid. Good work!
