Meth injection issue Misfires
And another issue i am also having misfires on #1 at idle i have checked the plug wire and even went back to stock coils i'm boggled could i have done something wrong when i changed the valve springs? Thanks guys
Yea man kevin actually brought u up he said u moved the nozzle and the missfire moved? And i have gotten rid of the msd wires using the 8.1 truck wires on the back and stocks on front back to stock coil packs from accels and i bought pure m1 meth from the local speed shop ran it straight same dam problem now he just told me had me buy a differnt plug ngk tr6 im sio sick of changing plugs with the 3in kit and the back manifold with heat wrap grrrr but im gonna try them in the morning
I thought the turbo kit did come with a Fuel pump booster
The Racetronix fuel pump rewire kit is suppose to increase voltage by 15-20 % and from what i understand is supplied with the Turbo Kit.
And to put duty cycle in layman's terms, it's basically how of the injectors capacity you're using at a given moment in time.
Yes, you are able to read this in HP Tuners.
