Spherical bearing upper mounts.
Old Oct 20, 2014 | 09:13 PM
91parkave's Avatar
Moderator
Default Spherical bearing upper mounts.
Just wanted to share my newest quest to improve handling. First i tried out the pillow ball camber plate deal, which was great but i need to do add'l engineering on keeping the strut assembly moving freely without binding. So for now im on new factory mounts, which maintains a good stack height, and also has a axial load of 44,000 lbs. More than durable for a DD for years. and years and rebuldable, as the bearings are held in place with against a race and secured via snap rings.
All thats required was some bronze bearings and washers of the M14 variety. You start with your Spring hat, use 2 washers, the bronze bearings which act as bushings in the bearing assembly, then the top plate another washer, then the nut. Grease between every point.
So far i got a couple of weeks and there solid as hell, but no friction in the steering whatsoever this time around.
Excuse all the grease and stuff, this is how i assembled everything, There was no need like i initially thought for 4 washers, which can lower the can while increasing strut travel slightly.
Stack goes like this
Old Oct 21, 2014 | 08:05 AM
x11 nut's Avatar
Great work man!
Funny enough I'm just finishing the same thing for my LS4 Citation build. In your first pic it looks like some sleeve/ bushings on the right side, did you use these and did you buy them or make them? I got bearings from QA1 but am looking at needing to make sleeves for strut to bearing..
Cheers
Old Oct 21, 2014 | 08:37 AM
91parkave's Avatar
Moderator
Originally Posted by x11 nut
Great work man!
Cheers
Nah the bronze bearings are the bushings that take up the space between the strut rod and and bearing.I'll snap some more pics
Old Oct 30, 2014 | 07:48 PM
91parkave's Avatar
Moderator
Updated for you x11nut with a little update
Old Oct 31, 2014 | 06:05 AM
x11 nut's Avatar
Thanks for the extra pics - where did you get the bronze bushings?
Old Oct 31, 2014 | 03:15 PM
91parkave's Avatar
Moderator
From my local ace hardware the strut shafts is 14mm
Old Nov 16, 2014 | 11:47 PM
ZSpeed07's Avatar
With these new mounts couldn't you eliminate the other bearings for the springs?
Old Nov 17, 2014 | 08:35 AM
91parkave's Avatar
Moderator
Not really with mcpherson style struts. You need as the bearings to prevent binding while turning on compression. You dont want to pivot on the strut shaft.
