ls4 in sts
Old Oct 22, 2014 | 08:30 AM
lsexpress's Avatar
Default ls4 in sts
will the ls4 fit in the sts northstar chassis? will it bolt up to trans?
Old Oct 22, 2014 | 10:21 AM
tonypaul's Avatar
fit- maybe, bolt up - yes, work - NO.....
Old Oct 22, 2014 | 02:28 PM
91parkave's Avatar
Moderator
Youd have to figure out a new mount situation, after thats figured out youd need to fugure out a CV axle replacment, as h body cars have typically longer shafts. After that you just need to figure out the electronics and youre all set.
Personally id stick with the 4T80/N*star, Turbo that ****** and be on your way.
Old Oct 22, 2014 | 05:51 PM
05GXPjake's Avatar
Isn't there some issue with mating the 4T80 and LS4 in our cars? Why would it fit better in the STS?
I think it'd be interesting to see this work though, especially considering that before I got my GXP I had an SLS (torque-tuned N* as opposed to the HP-tuned STS).
Old Oct 22, 2014 | 08:10 PM
x11 nut's Avatar
You need a starter boss alternative if you want to use a 4t80... The LS4 starter mounts on the LS4 specific 4t65. Otherwise it should look smaller in the engine bay because it doesn't have the N* overhead cams.
Old Oct 22, 2014 | 11:41 PM
91parkave's Avatar
Moderator
Yea the 4t80 is to big for the ls4 block unfortunately. The sts already has the 4t80 with the northstar. Too bad, that 4t80 can handle some serious power
Old Oct 23, 2014 | 06:05 PM
GXP25's Avatar
The STS is RWD...
Old Oct 23, 2014 | 07:43 PM
x11 nut's Avatar
Oh thats funny - I didn't even think about if it would be, got FWD on the brain!!
Old Oct 23, 2014 | 07:50 PM
91parkave's Avatar
Moderator
Well depends on what year STS we are talking about, the STS was front wheel drive the new body style changed to RWD
