LS2/LS3 valley cover for dod delete
Old Nov 16, 2014 | 02:56 PM
85SS/85GN's Avatar
Default LS2/LS3 valley cover for dod delete
What valley cover can I use for dod delete? Are they the same or different?
Old Nov 16, 2014 | 11:22 PM
tonypaul's Avatar
I used this one- http://www.briantooleyracing.com/6-2...-12598832.html
Old Nov 18, 2014 | 03:48 PM
85-308's Avatar
I'm also planning on the DoD delete. I have my engine out so it is easier to do 'other things' to it... like clean it out after.
I've just read that you can simply tap and plug the top holes in the block 'towers' that rise up to the underside of the valley pan and are sealed by the O rings.
That would definitely eliminate any flow to the lifters (which will be replaced by conventional anyway).
Has anyone done this? Is there any reason it wouldn't work? Then I could actually keep my current valley pan and simply turn off the DoD functions in the ECM etc. (I wouldn't - just to clean up the looks etc, but I could..)
Really cheap and easy alternative if you can deal with threading and the bit of mess...
Anyone?
GP
Old Apr 6, 2015 | 08:24 PM
bigfatls6's Avatar
Originally Posted by tonypaul
I know this is an old thread but Im looking for a valley cover to put on my ls3 im installing in my 98 corvette. With this one work with out the PCV?
